R50/53 How much warranty work is REALLY done?
Old Mar 12, 2006 | 12:36 PM
  #51
bamatt's Avatar
bamatt
05 MCSC no mods
boot latch replaced
seatbelt sensor replaced (caused airbag light to come on)
glove box lock replaced
rear bumper grill fell out & had to be replaced
I am going in this Friday for convertible top work as my top is stuck closed (UGH it's 83 & sunny here all weekend & I refuse to get in the Mini cause it makes me mad to drive with the top up Friday people kept looking at me like why is your top up so instead of driving this weekend I clayed & waxed )
It would also be interesting to start a thread to see how many times your dealer had the parts in vs having to make 2 trips & have parts ordered. I, unfortunately, have found that the dealer had to order parts 100% of the time even though I warned them of my problem well in advance of coming. Nothing like driving 500 miles (2 round trips) for a simple part
Old Mar 12, 2006 | 01:21 PM
  #52
sequence's Avatar
sequence
I know when I had my window regulators replaced I got the last two in stock, it was something like a two week back order for more because BMW seems to have a vendor that makes real crappy window regulators--too common a problem in all their cars going back many many moons.... Even the six and seven series suffer from the same malady.
And I had to come back to get my fuse panel door/rocker panel replaced because it had to be ordered. otherwise everything else was in stock. JB
Old Mar 12, 2006 | 01:46 PM
  #53
gokartride's Avatar
gokartride
I haven't taken my MINI in for anything warranty related that wasn't covered...and cheerfully so! Had two door panels replaced, window motor thingies, and probably a few other items I'm forgetting. And this doesn't even count maintenance items...wiper blades, oil changes, brake pads, battery. Bottom line, I've only put gas in this car...no other expenses. I should also add that the local MINI dealer I have service done at is pretty much top notch.
Old Mar 12, 2006 | 04:00 PM
  #54
MiniMaxx's Avatar
MiniMaxx
Originally Posted by BeRight
I have been considering a MINI but man I'd be hard pressed to make all those dealer visits. [img]images/smilies/eek.gif[/img] No dealers close to where I work.
Maybe I need to find work closer to a MINI dealer
Fear not: 2 MINIs, 31,000 miles=no problems (24,000/7,000)
Old May 9, 2006 | 09:03 AM
  #55
tshizzle's Avatar
tshizzle
*Dash Rattling:
They said it was "center guide pin". Removed dash, insulated pin, firewall, and dashboard. Replaced A-Pillars - No rattle FIXED
*E-Brake sensor was stuck on:
Said wire was loose from switch, just had to plug it back in. FIXED
*Cowl Vent Grills foam gone:
Replaced with newer model that doesnt have foam. FIXED
*Glovebox always opening:
Installed shims under glovebox screw - FIXED
*At "highway" speeds, whistle coming from pass. side area
Installed foam strip on recirculated air flap "as per sim" (whatever that means). FIXED
*Sunroof rattle:
Descreased spring tension on wind deflector flaps. Lowered headliner and replaced the front shade as well. FIXED
Old May 9, 2006 | 10:43 AM
  #56
Cheetos's Avatar
Cheetos
Ouch!
Brand new owner of a brand new MCS (2 weeks).
From the sound of things, my Elise might be more reliable! (never thought I'd say that about a Lotus).
Should I truly be expecting a clutch slave/master cylinder failure?
Old May 9, 2006 | 12:05 PM
  #57
chows4us's Avatar
chows4us
I think I read that happened to someone coming home from the dragon?
Old May 9, 2006 | 01:42 PM
  #58
Goose's Avatar
Goose
I'm going to take mine in for a new clock, since mine won't keep accurate time. I read about the TSB on this - does this count? Sorry if this doesn't help the stats.
Otherwise no problems on my (low mileage) '05 MCS.
Old May 9, 2006 | 01:47 PM
  #59
MINIotaple's Avatar
MINIotaple
You are reading a thread wholly based on MINI defects...
I'm sure if you went over to the lotus boards and did the same thing, it would be pretty long.
Old May 9, 2006 | 01:57 PM
  #60
Goose's Avatar
Goose
I'll second that about the Elise - very reliable even when compared to a "normal" car. Not to be disloyal to NAM, but EliseTalk is probably the best source for info on the Elise, if you weren't aware of it.
EDIT: Here's a link to EliseTalk - http://www.elisetalk.com/forums/index.php? My name is Goose there, too.
Old May 9, 2006 | 03:41 PM
  #61
Aviators's Avatar
Aviators
2006 MCS JCW
Cluch/Flywheel replaced (clutch chatter on cold 1st gear slow starts), driver's front R98 wheel replaced for 'clicking/ticking.'
Old May 10, 2006 | 12:01 PM
  #62
Cheetos's Avatar
Cheetos
Hi all. Looking at some responses to my post, I think I may have been imprecise. Not asking about the clutch cylinders on the Elise, but on the Mini.
I'm having a ball with the Mini, I'm just wondering, as a new owner, if I'm in for a ton of headaches, big and small.
Old May 11, 2006 | 02:36 AM
  #63
BlueCooperS's Avatar
BlueCooperS
Originally Posted by chows4us
Many people seem to be worried about "voiding" their warranty.
I'd like to know how many times ppl have in been in for Warranty work ... Dont care what it was ...
In many years, and in many cars, I've had warranty work done ONCE (not recalls either) (except for that miserable Fix-it-all the Time FIAT).
So whats the REAL scoop for the people who have had their MINIs for some time???
We had a FIAT 128. Never had warranty work done on it, but it sure went through parts like it was hungry for them. 5000 miles on plugs, 10k on brakes if you're lucky. Starters, alternators didn't last either. The parts were pricy like MINI parts. It handled nearly as good as a MINI but the engine wasn't so gutsy.
We've had warranty fixes on our car. Nothing big. The recall for emissions control...which included sofware and a new PCV pipe. Can't think of much else. The car hasn't been fixed much, mostly just modded.
(EDIT) I forgot, the air conditioner needed filled up 2 times. The first time, they put indicator refrigerant in it. The 2nd time, they noticed it had been leaking from a filler valve.
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
Emnotek
Aug 13, 2015 05:47 PM
rckrzy1
Aug 11, 2015 06:06 PM
