R50/53 Oil
Old Feb 4, 2003 | 06:22 AM
mmmark's Avatar
mmmark
A question for the oil experts onboard:
My mini has a bit over 7k miles on it, and it's going in for its first oil change on Friday. (We'll stipulate that I'm a procrastinating fool and should have had this done 3k miles ago.) This past Saturday, I checked the dipstick and it was down a whole quart. How could this be? How bad is it?
Old Feb 4, 2003 | 06:23 AM
mmmark's Avatar
mmmark
Let me add that I immediately purchased a quart of Castrol Syntec 5w-30 and put it in.
Old Feb 4, 2003 | 06:44 AM
OmToast's Avatar
OmToast
But it was my understanding that MINIs don't require their first oil change until 10K--or until it tells you, depending on your driving habits. I can't personally imagine the typ of driving one must do in order to make it think it needs an oil change at 3-4K. And I've also heard that the shop won't do an oil change prior to that unless you pay. :smile:
You can breathe easy now
~Kelley
PS. Not that anyone would ever tell you it's a good idea--and i must stress emphatically that it is not--but my mother drives her car regularly in a 2 quart deficit and it's got about 98K on it. Everything runs perfectly and her engine is peachy. Again, not that I condone this and one should never ever treat their MINI in such a fashion (or any car, for that matter) but just to ease your mind a bit.
Old Feb 4, 2003 | 07:26 AM
Casey's Avatar
Casey
Sure - oil changes might not be required till 10,000 miles but that is most defintely not the same as topping off. All cars will use a tiny bit of oil, leak a bit, or something and being down a tad bit after 7000 miles is not un heard of. I check my oil once a week in all my cars as well as the coolant to make sure fluids are at proper levels. Then again I'm at 11,000 miles and have already changed the oil 3 times.
Old Feb 4, 2003 | 12:23 PM
retroom's Avatar
retroom
Using one quart of oil in 7,000 miles is nothing to worry about, since the engine uses oil during break-in. Your other car probably would use the same after 7000 miles but you'd never notice because of more frequent oil changes.
retroom
Old Feb 4, 2003 | 12:38 PM
rrmixn's Avatar
rrmixn
After picking my "S" up with 450 miles on it the oil was 3/4 qt low. When I did the first oil change at 1750 miles I was another qt low. I know high-performance engines burn a little oil but is this too much?. My 5.0 mustang uses 1 qt every 2500 miles, just in time for a oil change. This is the first car I've had synthetic oil in and I've also heard that Castrol has more burn off than other synths. I changed to Mobil 1 and we'll see how that works. Next oil change 5K.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
