R50/53 Calling all S owners w/LSD
Originally Posted by lhoboy
I've already installed the '05 trans/LSD on my '02 MCS. That has had a bigger performance impact even than installing the '05 JCW tuning kit. I've used a quaiffe on another car in the past. It was perhaps a bit better on straight line getaways, but the MINI LSD is far more predictable in the twisties.
I have expected that your impression is correct, that the gearing difference delivers a performance gain that is similar to that delivered by the JCW style motor mods.
Originally Posted by BFG9000
Speed-sensing diffs like the viscous type they sell, and some lockers, allow a certain speed differential threshold and then lock the wheels together absolutely. Best for off-road traction, but the sudden onset and high degree of locking obviously plays havoc with steering and ABS.
, but it was unstoppable off road. A few times I actually jumped out to watch while it crawled along at idle over rocks in low-range 1st, then climbed back in.Sorry... back to our technical discussion.
I guess they don't care that everyone else in the world considers Auburns and clutchpack diffs to be friction-type devices, where there is a preload (the source of the groaning sound in turns, and also the only amount of friction when one wheel is in the air) as well as increased friction under load (torque). Torque-reactive, yes, as the spider gears do wedge the clutches together more tightly under load from any source (including brakes). But TORque SENsing, no!
I really like my Detroit Locker. Around turns it goes click-click-click loud enough to echo off other cars
I've had Auburn-type diffs before and they never made any noticeable noise. But Auburn does require addition of a slip modifier: http://www.auburngear.com/aftermarke...chure_2000.pdf
Sadly, it appears even Auburn have now started calling them torque sensing
, but we know the difference. The cone shape merely gives much more surface area than the usual clutch type, though you'll notice the service kits contain no friction materials (carrier housing, side gears). So when they wear out they are disposable.
I even have a Phantom Grip and while it works fine on my lightweight car (nothing else is available for it), I would not recommend it for something as heavy as the New Mini. It has very little friction surface resulting in low preload and low torque transfer capability. Would work pretty much like a worn-out friction diff on a heavy car.
Xalfa, I would call those Air Lockers Driver-Sensing diffs
. They sense when the driver has pushed the button.
And lhoboy, that may be because the steering theoretically tightens up each time you get on the gas with the Quaife, where the friction types only tighten after slip is occurring when you are probably too busy to notice. My only Quaife equipped car has three Quaifes, so I hadn't noticed.
.I've had Auburn-type diffs before and they never made any noticeable noise. But Auburn does require addition of a slip modifier: http://www.auburngear.com/aftermarke...chure_2000.pdf
2.) What kind of oil should be used with an Auburn differential?
It is important when installing Auburn differentials that a high quality, non-synthetic 80w90 GL-5 oil, treated with GM or Ford limited-slip additive (also known as friction modifier) be used. Three ounces of additive will treat one quart of oil.
3.) What is clutch chatter?
Clutch chatter occurs when the clutch cone engages and disengages the case in rapid succession. This creates a noise called clutch chatter. Although noisy, it causes no damage and can be cured by using the correct oil and friction modifier as described above.
, but we know the difference. The cone shape merely gives much more surface area than the usual clutch type, though you'll notice the service kits contain no friction materials (carrier housing, side gears). So when they wear out they are disposable.I even have a Phantom Grip and while it works fine on my lightweight car (nothing else is available for it), I would not recommend it for something as heavy as the New Mini. It has very little friction surface resulting in low preload and low torque transfer capability. Would work pretty much like a worn-out friction diff on a heavy car.
. They sense when the driver has pushed the button.And lhoboy, that may be because the steering theoretically tightens up each time you get on the gas with the Quaife, where the friction types only tighten after slip is occurring when you are probably too busy to notice. My only Quaife equipped car has three Quaifes, so I hadn't noticed.
Originally Posted by MCLeonard
This is something that I was thinking about doing. Did you buy the trans new or were you able to find one salvage? Could you share about what this cost for the trans and the installation.
The LSD noise can be immediately cured by having your dealer replace the factory lubricant with the replacement lubricant recommended by MINI.
MINI has not started a "Campaign" to replace the oil, however, there is a Bulletin. If your SA is not aware of this, tell him.
The change in lubricant is all it takes to kill the groan. The new one has an additive that does the trick.
Trust me - I went through this. Had the groan, and now don't.
=R=
=R=
The worst part of having a Quaife LSD is when I apply too much power around a turn, I understeer off line. Whereas without LSD, I'd spin the inside tire and loose speed...I'd rather have traction control with my right foot than steering control with one tire anyday
SB: I don't have any knowledge as to what the Bulletin is called, however, it advises that if a customer complains about the "groaning" sound the lubricant is to be changed.
Dealers are not routinely changing the product, only if the customer initiates the conversation.
How dumb is that, anyway?
=R=
=R=
Does anyone know if the new oil decreases the effectivness of the LSD? That is my only reservation about having the oill changed. The noise is caused by slippage of the cone clutches in the LSD, if reducing the noise also reduces the friction between the cone clutches I would not want to do it. I want the strongest LSD effect that I can get.
Any help here? Anyone really know?
I have a 2006 MCS with LSD built on Nov 14th. My LSD makes no noise what so ever & to me appears to work very well. I'm guessing that it's got the latest lube in the tranny.
Chuck
Chuck
Chuck
Chuck
For awhile it was getting louder and louder, now it seems to be getting quieter, or maybe I am just getting used to it. We'll give it a few more miles and see what happens.
But if anyone has real information about how or why the new oil quiets the LSD I would like to know.
The slip modifier is likely similar to that used in some ATF. That only affects slippage at low pressures but does not increase slippage when the wet clutches in an automatic transmission are fully applied. Theoretically, this may mean the LSD action could be made nonlinear but that ultimate friction should remain unaffected.
According to my MINI service guru, the new oil has an additive in it. The noise could be eliminated by the simple addition of a third party additive, but MINI insists that the original lubricant be completely drained, and the newer stuff (with the additive) be used.
My guy says it's a bit of a money grab, because the dealer has to buy a full 5 gallons of the lubricant at a time!
=R=
=R=
Originally Posted by Bilbo-Baggins
I picked mine up on Nov 5th and I had heard talk about the new oil well before mine was made and assumed that mine would have the newer oil, but who knows. Maybe they don't install it from the factory. Mine didn't make any noise for the first 1,000 miles.
Chuck
Originally Posted by GmanViz
Do any of you notice noises from your limited slip at low speeds when turning tightly?
Technical Service Bulletin to change oil is finally here!!!
Issued in March 2, 2006...don't be surprised though if your SA doesn't know it yet. I found it by following a trail of posts from here to MINI2 forum. TSB# is SE M 23 01 06. I have sent an email to my SA and will wait for reply. The TSB describes changing the transmission fluid with Texaco MTF94 (P/N 83 22 403 247). It also says it is "Covered under the terms of the MINI New Vehicle Limited Warranty". Can't wait to get this done! Sorry but I don't know how to post the bulletin here. For those who don't know, this is to address the "groaning/grinding" sound of the LSD.
That's interesting. My car has just over 1,200 miles & she's still quiet. I'll be listening for any changes & following this thread.
Chuck
Chuck
Maybe the next time I am in for service I'll have them change the oil in the diff.
Just hope that it does not decrease the effectivness of the LSD, that would really tick me off.
I'll give them a call tomorrow.
