R50/53 Fender Scuttles loose
Old Jan 15, 2025 | 05:55 PM
Tombstone's Avatar
Tombstone
Does anyone have problems with the R53 Fender Scuttles fitting loose , I've seen a lot of info on removing the side scuttle, but after re-attatching mine it seems to be much looser than before.
When re-attatching, i got the firm and assuring 'click', but it seems to sit a little sloppy, and have more movement than before removing it.
Just curious if anyone else has experience this? Any suggestions that work would be appreciated…
Old Jan 16, 2025 | 05:32 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Yes. My left side scuttle also seemed much looser than before after changing the bulb. I'm not sure why, since I had only removed it's lens. I employed the lazy way by using a very small dab of E600 flexible adhesive glue to help secure it from sliding around. Other than that ; I never really spent much time trying to understand what the problem was since I didn't find any broken tabs.
Old Jan 17, 2025 | 10:33 AM
BRGPA's Avatar
BRGPA
Mine were a little loose a few years ago, and I used a bit of Elmer's rubber cement to stop them from moving. I liked that any excess can be removed by rubbing and it's strong enough to work while still making removal easy.
alistaircookie
Jun 25, 2019 11:31 AM
Vinyl Styles
Sep 3, 2013 08:11 PM
