R50/53 Cruise control issues after box change
Old Dec 25, 2023 | 04:19 PM
Swiftly's Avatar
Swiftly
Hi,
I have recently had my gearbox changed on my R52 (2005) I had checked both cars on RealOEM to check they where both the same gearbox which they where (New box from 2006 R52).
Since the replacement cruise control only seems to work in 3rd gear and won’t trigger in any other gear, the light does not flash or anything just does not engage.
Would anyone know how to fix this issue? I have seen this issue appear in other threads but no one ever seems to add the fix.
The doner car did not have cruise control no idea if that’s an factor
Cheers
Callum
Old Dec 26, 2023 | 03:06 PM
adriancl's Avatar
adriancl
You have different gear ratio now.Only way to solve the issue, is to write new gear ratio in Engine Control unit.
Old Dec 27, 2023 | 02:39 AM
Swiftly's Avatar
Swiftly
I didnt think the gear ratios would change with them both been Getrag gearboxes. Would you know how to code new ratios? I do have ISPA (Or whatever its called) so i have a semi understanding in coding the minis
Old Dec 27, 2023 | 06:17 AM
adriancl's Avatar
adriancl
ISTA not work, need to reflash Engine Control Unit.I can give you more details in PM or by Messenger at this profile:
https://www.facebook.com/nastase.adrian.313
Old Dec 27, 2023 | 06:21 AM
Swiftly's Avatar
Swiftly
cheerw mate I have popped you an message on Facebook 😊
Swiftly
Sep 20, 2024 03:20 PM
EkimOiramed
Navigation and Audio
Mar 21, 2024 04:04 PM
Matthew Hallmark
Apr 16, 2021 01:41 PM
Kitchenboy
Mar 29, 2020 08:34 AM
mrhappy
Jan 20, 2020 04:31 PM
