R50/53 Engine off Whining noise from engine bay
Old Oct 3, 2022 | 07:04 PM
iss49698's Avatar
iss49698
Hi all. We have a 2005 MCS 6 speed with 160K miles on it. My wife came home and I noticed a high pitched whining noise after it had been sitting with the engine off in the driveway. Steering appears to be fine. Noise is more pronounced under the vehicle. I put my hand on the power steering fan and I can feel a slight vibration and buzzing. Any suggestions would be appreciated. In the meantime I disconnected the battery. Thinking I could take the fan off tomorrow bro test it? Thanks
Old Oct 3, 2022 | 09:25 PM
RB-MINI's Avatar
RB-MINI
Checking the fan is quick as they out in the open, under the car, but it sounds like the power steering pump was stuck on which is a known issue. Good call on disconnecting the battery as the best case scenario would have been a dead battery, and the worst would be your MINI catching fire, which is also known to happen
The sealed electric power steering pumps build up carbon dust from the brushes which shorts out the circuit board and makes the pump run with the key off. Check your VIN at the link below to see if your power steering pump, or anything else, is still under recall. Even if not, if you bought the car less than two years ago, call the dealer to see if the recall was done, or the pump was replaced less than two years ago and still falls under their 2 year parts warranty.
https://www.miniusa.com/owners/tools...rt/recall.html
Old Oct 4, 2022 | 07:48 AM
iss49698's Avatar
iss49698
Thanks so much. Greatly appreciate your help. We are the original owners and that pump is 17 years old.
miniuy
Oct 16, 2022 10:52 AM
dlroto
Sep 24, 2007 07:00 PM
Chips-O'Toole
Jan 23, 2003 06:13 AM
