R50/53 Strut tower braces for convertibles
Old Dec 24, 2021 | 07:57 PM
Tombstone's Avatar
Tombstone
Is anyone running strut tower braces on their hatchbacks; the OEM one’s that mount from strut tower forward to the frame horn?
Old Dec 24, 2021 | 07:59 PM
deepgrey's Avatar
deepgrey
​​​​​​​Yes.
Old Dec 24, 2021 | 09:18 PM
Fly'n Brick's Avatar
Fly'n Brick
Plus tower defenders.
https://www.waymotorworks.com/strut-...0-r52-r53.html
Old Dec 24, 2021 | 11:13 PM
OCR's Avatar
OCR
Tombstone -
Something to think seriously about, that it if you want to "actually" help strengthen the tower from "mushrooming", DO NOT use the plates that are bolted onto the "top" of the shock tower (visible).
The type that are used between the shock mounting plate (the ones that can't be seen) and the tower are a MUCH better design. They actually, more evenly spread the forces from hard hits from hitting pot holes, tire stops, rocks, etc. The ones bolted on top help to keep the three studs mostly straight up and down, but don't do as much as they "could" as if they were on the underside of the strut.
High school physics, 101.
As for the tower struts... Again dynamics and physics wise, get a "straight" bar, like the BMW, JCW bar. It's straight for a VERY good reason. There a few on the market, search them out. Bars with bends are just paper weights. Again, you can verify this talking to any Junior Collage Mechanical Engineering or Physic's teacher. A bar with a bend in it, is ACTUALLY a spring. A straight bar is MUCH more resistant to collapse than a bar with ANY...sort of bend in it.
When I bought my 05 JCW, it had a tower strut bar. It had a small bend, one at each end. That bar has now been removed and I replaced it with a straight bar.
One more thing, but it's a little more involved. Bar kits that have "oval" mounting holes, end up acting much like a bar with a bend in it ! You can and should make shims, or spacers to close up the space left by the room in the oval hole. I also did this to my car..!
This is called a "friction" joint. Friction joints will easily slip when forced. But a spacer to fill the hole prevents this slip and makes the joint many, MANY times stronger.
Mike
Old Dec 25, 2021 | 06:24 AM
deepgrey's Avatar
deepgrey
Originally Posted by OCR
Tombstone -
Mike
He’s asking about the cabrio braces. They quieted some of my dash rattles. Other people have claimed that they make a difference in handling. I can’t say I noticed anything, but that doesn’t mean it’s not there.
edit: These.
Old Dec 26, 2021 | 09:26 AM
Husky44's Avatar
Husky44
I am.
I installed these last among the many chassis-stiffening mods I have listed in my signature. They didn't make a discernable difference at that point, but might be more noticeable on a less modded car.
What is it you are trying to achieve?
Ladyvalea
Suspension
Feb 4, 2010 12:55 PM
Mini Cooper S
Suspension
59
Mar 1, 2006 05:30 AM
royce
Suspension
Feb 3, 2006 01:29 PM
bigpmj
Oct 30, 2004 04:32 AM
