R50/53 2003 MCS Random high idle with code p0507
Old Oct 15, 2021 | 09:00 PM
Mtb Awesome's Avatar
Mtb Awesome
Hi all so my mini popped a code on my ultra gauge (similar to scan gauge) a p0507. At the time it was idling high so i pulled over and checked the fuel vapor vacuum hose on the back of the intake. It was not loose but I double checked it since that has been a problem before. I kept driving and it started idling normally again but the code remained in the system. Throughout today it has idled normally and a tad high randomly at stops (about 850 to 900 rpm). Just even when normal for a long period of time such as tonight it would still pop the code on my gauge. I would assume this is a vacuum leak of some sort, but since it randomly idles high Im not too sure. Any input to what it could be would be greatly appreciated!
Old Oct 16, 2021 | 07:09 AM
ssoliman's Avatar
ssoliman
I’d guess air leak. You could try a smoke test.
could be the map sensor?
Old Oct 16, 2021 | 07:49 AM
Mtb Awesome
Was thinking it could be one or the other it's just the randomness. I would think if it was a vacuum leak it would idle odd all the time right?
Old Oct 16, 2021 | 05:53 PM
ssoliman's Avatar
ssoliman
I would think so.
the sensors going out can act very randomly it seems
Old Oct 16, 2021 | 05:54 PM
ssoliman's Avatar
ssoliman
What do trims look like?
Old Oct 16, 2021 | 05:58 PM
Mtb Awesome
Short term trims are lean at idle seems to be at -6 to -8 granted I also have a 15 percent pulley if that makes a difference.
Old Oct 16, 2021 | 06:07 PM
ssoliman's Avatar
ssoliman
If trims go correct with throttle (say 3 or 4K rpm) that would indicate an air leak.
if not I’d go with sensors. Map, pre-cat O2
Not sure on the pulley
Old Oct 16, 2021 | 06:10 PM
Mtb Awesome
What would be the range of correct trims for those rpms? And also about a month ago I accidentally installed the upper manifold heat shield on top of the O2 sensor wire and cooked it a tad would that cause it to fizzle out like this a month later?
Old Oct 16, 2021 | 06:16 PM
ssoliman's Avatar
ssoliman
My trims fluctuate.
-5 to +5. Usually less. Stock engine.
Old Oct 17, 2021 | 07:26 AM
Mtb Awesome
My trims fluctuate.
So after some highway driving this morning at around 3k 6th gear 65 mph my fuel trim seems to be bouncing alot goes from -1.6 to 7 and everywhere in between. Granted I also had cruise control on to eliminate human error. Does that seem normal? Also with a Alta intake and 15 pulley no tune.
Old Oct 17, 2021 | 07:28 AM
Mtb Awesome
This is idling at a stoplight when it decided to idle high a bit dim on the gauge but do any of those numbers scream any sort of sensor or vacuum leak?
Old Oct 17, 2021 | 08:20 AM
ssoliman's Avatar
ssoliman
Trims seem ok.
high idle is normal I think when the ac kicks on. Not sure tho my ac has not worked in years (planning to swap the evaporator at some point)
So ac. On or off?
Old Oct 17, 2021 | 09:46 AM
Mtb Awesome
Trims seem ok.
So ac. On or off?
Ac off radio off everything off.
Old Oct 18, 2021 | 01:18 PM
ssoliman's Avatar
ssoliman
Well scratch that off the list
Old Oct 18, 2021 | 03:55 PM
Mtb Awesome
Would a boost leak cause this is sure like maybe the intake pipe that goes to the supercharger is leaking because I am low on boost but it has been for longer than this issue has occurred.
Old Oct 18, 2021 | 09:09 PM
ssoliman's Avatar
ssoliman
I’d lean towards no on that. No boost at idle.
as far as I know idle is a function of readings from the map and O2 sensors (pre-cat).
so one of those sensors or an air leak.
Sounds like you did a smoke test already? If no leaks, I’d start replacing sensors but that’s because I don’t know better
Old Oct 18, 2021 | 09:29 PM
Mtb Awesome
Alright appreciate the help I haven't done a smoke test yet but definitely will hopefully nothing too bad is at fault.
Old Oct 19, 2021 | 05:29 PM
ssoliman's Avatar
ssoliman
Cool I have a link to a smoker if u need one…
Old Oct 22, 2021 | 07:49 PM
Mtb Awesome
Ok just one more thing i noticed last night not sure if this would have anything to do with this issue. Granted I have not had the time to test any of the sensors or preform a smoke test. When I turn my headlights off my rpms tend to exceed 820 but when they are on the car idles normally is this something related to a possible alternator? Battery is from 07/20 so probably not the battery right?
mini907
Jun 8, 2019 06:12 PM
sickboi55
14
Mar 2, 2014 03:47 PM
malteseracer
Jun 5, 2012 03:32 AM
eduel
Jan 10, 2011 05:26 PM
LordOfTheFlies
Jan 24, 2006 08:20 PM
