R50/53 P0036 code need help
Old Sep 1, 2021 | 02:48 PM
theDonVon's Avatar
theDonVon
So the other day I seen a ground hog go under my car. I went out to start it to go get it inspected now I have a cel light and the code is p0036 I have reset it multiple times. Checked the wiring on the post 02 sensor and can't find anything.. this is really frustrating since today is my last valid day for my inspection.
Old Sep 1, 2021 | 05:52 PM
BlwnAway's Avatar
BlwnAway
I'm confused...
p0036 is a heater circuit code, nothing to do with the post CAT o2 sensor?
Old Sep 1, 2021 | 06:06 PM
ChiefM's Avatar
ChiefM
Code P0036 is a generic diagnostic trouble code (DTC) that's set when there's a potential fault in the downstream oxygen (O2) sensor's heater circuit. ... The faster the heated oxygen sensor reaches that temperature, the faster the sensor will start sending an accurate signal.
Replace the 02 sensor, nothing to do with the ground hog.
Are you running premium fuel?
Old Sep 1, 2021 | 06:30 PM
theDonVon's Avatar
theDonVon
R53
I always run premium 93. What's the best/cheapest 02 sensor to go with??
Old Sep 1, 2021 | 06:35 PM
theDonVon's Avatar
theDonVon
R53
These are the codes i had. Now i just have the fault p0036 that i clear and comes back after like 1-2 start ups
Old Sep 2, 2021 | 01:56 AM
ChiefM's Avatar
ChiefM
I have an R50 non blower and found these on Amazon;
Amazon Amazon
I reset my ECU and filled my tank with premium and the 02 light went out on mine. I just got the car so I have no idea what fuel it had in it, I also just replaced the CAT so you might not get the same results but it worked on mine.
Old Sep 2, 2021 | 03:53 AM
nd-photo.nl's Avatar
nd-photo.nl
I bought 2 Magneti Marelli's for my R53 JCW, they were about 30 euros a piece here in NL. I had a VEMO once, but that one gave errors after a very short time, never again for me.
Old Sep 2, 2021 | 05:23 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Don't waste your money with non OEM oxygen sensors sensors trust me, I burnt one out every 2 months until I got sick of it and finally bought an OEM1 and it's now lasted past the 2 months finally .
Old Sep 2, 2021 | 11:24 AM
theDonVon's Avatar
theDonVon
R53
and that fixed your problem?? Did you have the same code? P0036
Old Sep 2, 2021 | 01:06 PM
BlwnAway's Avatar
BlwnAway
Lol...
I guess my code library wasn't wrong, it was just incomplete...
Oops.
kandpand
Aug 4, 2021 10:10 AM
Creeve
Jan 11, 2012 01:37 AM
nolimit
22
Jan 20, 2009 11:36 PM
Xiek
Aug 26, 2008 05:39 PM
SuperCooper04S
Apr 19, 2007 10:38 PM
