R50/53 Changing Waterpump...do I have to pull the SC?
The o-ring where the water pump snout goes into the block is leaking coolant. Is there a way to just pull the waterpump off of the back of the SC in order to get access to that flange seal, or am I going to have to pull the entire SC off? I just had the SC off to service it last weekend, but I must have nicked that o-ring on the water pump where it plugs into the flange on the block.
If I don't have to pull the SC again....that would sure same me lots of time.
Thanks!
Thanks!
Well....I just got it all back together. It was actually pretty easy. I ended up taking off the flange where it bolts to the block, and just took that and the water pump off as one assembly, made it much easier.
I cleaned everything up, put two new orings on it, pressed the flange onto the waterpump snout, and then installed it all as one piece. I left the flange bolts lose until I got the water pump tight, and then tightened the flange. It saved me a bunch of time doing it that way vs. taking the serpentine belt off, alternator, and pulling the SC...probably saved me a good hour or two.
Unfortunately...I snapped that grey pipe that goes to the map sensor and connects to the intake tube....so now I have to either attempt to find one locally, or JB weld it. Hopefully I can find one locally.....
Been there, happened to me when I did my service earlier this year. Best not to mess with it and source a replacement. They're not that expensive, maybe $30-$40
GearheadS
Jun 27, 2024 06:52 PM
robj
Oct 23, 2019 05:15 PM
youloze
Aug 5, 2013 04:17 PM
