The power steering sound might be normal since the electric pump usually has a whine to it.
On the key/battery, if you don't want to do it yourself, there's a member on here who has repaired or replaced the batteries for others in the past. This post he started has info on early, face-lift rechargeable, and flip-key modifications: https://www.northamericanmotoring.co...rbishment.html
So it looks like my stereo is toast. It is stuck on 1 channel and I can't change it. None of the buttons work. I am looking at getting a cheap stereo off of ebay. What do I need to install it? Car Stereo Would this one work in the Mini?
I have no idea you can get a new head unit that cheap. This is why there is this trade war brewing . Unless you have HK, I don't see why not, if you are an undiscriminating audio listener. I have given up on advising people on audio fidelity. It is like straight ahead jazz. You either get it or don't.
It should come with a single DIN basket which should fit right into the Mini's single DIN slot. You will need to either but the connectors off the factory harness and splice into the wires, or buy a harness adapter if you want to preserve the ability to revert back to the OEM HU. Since you are going all cheap, I will not bother with the adapter.
Thank you for all your help. From what I have read I will need an antenna adapter ISO-Din to make the radio work. I wonder if I would also need a fascia plate or would it just fit in there?
Yes, the Mini HU uses a funky European antenna connector. You will need an adapter. The eBay HU should not require a facia plate if it is true single DIN. I would just wait if I were you.
If your speaker grill looks like this, you have HK, and the HU swap gets very complicated. And most likely you also have the steering wheel control too.
Good. You are now up to speed. I actually forgot that you do need that facia trim but I did mine change 12 years ago. You are on your own now. Do remember the steering wheel control adapters typically are made for the name brands.
I know that now. There is a lot to know. That is why I changed from a generic stereo to a pioneer. The link above supports Pioneer. Little more than I wanted to spend but it will all work.
I just pulled my stock receiver out of my 04 R53 HK system...the amp was toast so I'm replacing everything....the receiver is yours for the cost of shipping from NC if you want it
Wow that is very nice of you . Will this even work? I only have the base HU and not the HK .
