R50/53 Brake bleeder screw disparity
Over the weekend, I put my car up on stands for the task of pressure-bleeding my brakes/refreshing the fluid. Initiated the process with the usual sequence of RR, LR, RF, LF...
I have a combo offset 10/11mm wrench I brought over to the right-rear caliper to start, and needed the 11mm side of the wrench to loosen the bleed screw. So I bled that brake and moved to the left-rear, where the bleed screw needed the 10mm side to loosen... On both the fronts the bleed screws required 10mm as well.
I assume that someone, at some point replaced the bleed screw on my right-rear caliper with this larger 11mm screw -- and this is not the way the car was equipped as new?
Would this indicate that the original bleed screw was broken at some time in the past, and the hole tapped larger for the screw that took an 11mm wrench to loosen?
It's not a big deal, as the larger screw functioned properly -- it's just an oddity I discovered in the process.
Also, I'm going to throw in a recommendation for the ECS/Schwaben 3-Liter European Pressure Brake Bleeder. It's the best designed unit I've seen, with solid connections and the separate pressure-release fill plug that made the chore extremely easy and neat.
Most likely. Replacement screws can have different sized hex heads on them but the same thread size.
Most likely the head of the original one got rounded off and the replacement came from napa or somewhere, same thread, different hex.
