R50/53 Who's done a cam swap on a daily driver R53?
Old Aug 4, 2016 | 05:51 AM
  #26
Saltysalt's Avatar
Saltysalt
take the valve cover off and see if there are any non MINI marks on the camshaft
Old Aug 4, 2016 | 05:52 AM
  #27
Saltysalt's Avatar
Saltysalt
Originally Posted by bavmotors
I'd have to agree, doesn't look like a worthwhile mod, I thought with a tune and bolts ons it would be an easy 10hp gain.
usually it is.... and I wanna think that the power gain on that auto was from the A/F being much leaner on the top end
Old Aug 4, 2016 | 06:02 AM
  #28
IQRaceworks's Avatar
IQRaceworks
Originally Posted by Alan Snow
After reading this thread, I'm starting to think my used MINI I bought might have had a cam put in, cause it's impossible to accelerate at all under 2k RPMs. Idles fine and all that jazz, but if I'm cruising, and I hit too high of a gear and it goes under 2k, I may as well take my foot off of the gas, cause I'm not going to go anywhere any time soon. Pop it down a gear or two to get above 2k, or around 3, and the thing flies like a rocketship.
How can I investigate this without motor disassembly? Can I even?
No, you probably just have the stock cam. Mini S motors are dead under 3000rpms......you are not making much boost, and the supercharger is just a parasite to engine power at low rpms. That's just the nature of a little 4cly motor designed to make all its power with boost.
You pointed out the main reason for my post.....the R53's are already gutless at low rpms, I wanted to make sure a cam didnt make them ever worse.
From everything I have seen from people in this thread, it looks like the gains from a cam swap are very small, and usually only help at very high rpms. Great for a track car, not worth the time and money for a street car.
You figure that you could do a cam swap for $400+ when its all said and done ....probably add $400++ if you need a custom tune to make it run right....probably add $500+ if you have a shop do the cam swap for you. That's a lot of money for a top end gain of 3-6hp.
You would probably have a better driving car by putting all of that money in suspension and/or brake upgrades.
Old Aug 4, 2016 | 06:06 AM
  #29
Alan Snow's Avatar
Alan Snow
Well, to be fair, mine is making 16lbs of boost, and has an assortment of mods, like the SC pulley, braided brake lines, etc. The prior owner really cared for the car, and it makes me think he may have done things to it I can't see without taking a wrench to it.
Old Aug 4, 2016 | 07:07 AM
  #30
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
audio131 has !
And it sounds like a real "Beast".
Old Aug 4, 2016 | 07:52 AM
  #31
IQRaceworks
Originally Posted by -=gRay rAvEn=-
audio131 has !
...but how does it run?
Old Aug 4, 2016 | 08:13 AM
  #32
-=gRaY rAvEn=-
Moderator
I think he purchased it from Way.
You would have to check with him.
Was running great when he drove it here to RI !!
Roared like a beast, when revving the engine with hood up I almost needed ear plugs...
Old Aug 4, 2016 | 11:38 AM
  #33
Saltysalt's Avatar
Saltysalt
one of these days ima have to meet up with you gray, im down in south Kingstown frequently, matter of fact ill be down this weekend! haha
I need to go for a ride in a car with a cam.... to sway my decision
Old Aug 4, 2016 | 11:46 AM
  #34
chris.j.lamb's Avatar
chris.j.lamb
The newman fast road not the race one
I can feel the extra torque over 4k
Idle is a little lumpy but i like that
Car Care Products
Mar 17, 2016 03:35 PM
cargusjoh
R55 :: Clubman Talk (2008+)
Mar 17, 2016 12:18 PM
cargusjoh
Mar 17, 2016 10:06 AM
Mar 14, 2016 09:59 AM
