R50/53 0psi Boost
Old Mar 4, 2016 | 12:22 PM
AT Productions's Avatar
AT Productions
0psi Boost
okay so i installed my boost gauge and now im getting 0psi of boost....
one of the Intercooler Bellows screw stripped out so now it isnt sealed and there is stuff coming out to the bottom now so is that why i have no boost?
Old Mar 5, 2016 | 06:25 AM
X757XVeritas's Avatar
X757XVeritas
Stuff? Little more description would help, but I suspect that you have a major boost leak from your description.
Old Mar 7, 2016 | 12:04 PM
IQRaceworks's Avatar
IQRaceworks
Even with a small leak, you should still be seeing SOME boost. What type of gauge is it? Electronic...or is it an analog gauge with a small piece of tubing going to your intake to read boost?
Maybe a silly question....but are you sure the gauge is working correctly?
Old Mar 7, 2016 | 12:38 PM
ZippyNH's Avatar
ZippyNH
Well...if the IC boot can't seal...You will get a huge boost leak...so that is the first problem to solve. If the clamp is upsidedown, it will act stripped...try inserting the bolt from the other side of the clamp....
Turbojace
May 24, 2016 07:24 AM
yrwins acosta
R58 :: Coupé Talk (2012+)
15
Mar 8, 2016 05:48 AM
WayMotorWorks
Mar 3, 2016 09:33 AM
sirr6
Electrical
Mar 2, 2016 04:33 PM
yrwins acosta
R59 :: Roadster Talk (2012+)
Mar 1, 2016 11:50 AM
