R50/53 R50 Cooper Rebuild Let the Fun Begin! :popcorn:
Old 01-11-2016, 06:29 AM
Kahnfucious's Avatar
Kahnfucious
Kahnfucious is offline
So after all this work are you going to be putting full coverage insurance on the car?
  #77
Old 01-11-2016, 12:28 PM
Racingguy04's Avatar
Racingguy04
Racingguy04 is offline
I saw you used screw type clamps on the CV boots. I just replaced my inner boots and the clamps were a PITA but I thought that screw clamps wouldn't work due to clearance and not getting tight enough, do you know something I don't? I've never dealt with cv boots before.
  #78
Old 01-11-2016, 12:47 PM
Kahnfucious
I don't think either of those is an issue...as long as there isn't a huge extra tail hanging off of it I think clearance should be fine. As for tight enough - as long as you can turn the screw tight should work. I bought the tool to do the crimp style clamps when I did mine but I don't think it was 100% necessary.
  #79
Old 01-13-2016, 05:40 PM
MazMini's Avatar
MazMini
MazMini is offline
Ohhh Yeah!!! Thats for sure!!! Either way its a fun project and not too expensive... Still comes out less than the exhaust I just put on my S4.. lol
  #80
Old 01-13-2016, 05:41 PM
MazMini's Avatar
MazMini
MazMini is offline
Not really like stated before as long as you do not have a long tail and it doesnt snag on anything it will be good...
  #81
Old 01-13-2016, 06:50 PM
MazMini's Avatar
MazMini
MazMini is offline
Huge update!!!!!!!
FINALLY MAKING SOME HEADWAY HERE SO HERE GOES...
- AFTER ALL THE HARD WORK THE SUB FRAME WAS FINISHED UP AND READY TO BE INSTALLED. I TOTALLY FORGOT HOW HEAVY THIS THING WAS ONCE EVERYTHING WAS INSTALLED. IM SUPER EXCITED TO FEEL HOW TIGHT THE FRONT END IS GOING TO BE AFTER THIS....
- GOT IN THE SEAL THAT WAS HOLDING UP ME PUTTING ON EVERYTHING ELSE.. NOW WE CAN START MOVING FORWARD..
BUUUUUUUUUUUUUUUUUUT NOOOOOOOO!!!! AS USUAL SOMETHING GOES WRONG!!!!
- AS IM TIGHTENING THE BOLTS WITH MY WEAK *** BATTERY DRIVER GUN.. THE BOLT SNAPS.. OHHHH WAIT ITS GETS BETTER...
- I DRILL OUT THE BOLT AND EVERYTHING IS GOING FINE. STICK THE EXTRACTOR BIT IN THE HOLE I JUST DRILLED AND GUESS WHAT.. THAT SNAPS OFF TOO! (KEEP READING)
- I HAD TO GO TO LOWES GET A SMALL TITANIUM DRILL BIT.. DRILL OUT AROUND THE BROKEN BIT.. TAKE A SMALL PICK AND PICK IT OUT... FINALLY GOT IT OUT THE NEXT DAY...
- i GOT NEW BOLTS AND WASHERS AND TORQUED IT ALL DOWN.. FINALLY DONE!
- NEXT WAS PUTTING IN THE GEAR OIL.. I TOTALLY FORGOT BUT BECAUSE ITS EASILY ACCESSIBLE IT WASN'T TOO MUCH OF A PROBLEM. THE PUMP FROM AUTOZONE WORKS WONDERS.
- I CLEANED OF THE RIGHT PART OF THE MOTOR AND FINISHED PAINTING THE BLOCK BETWEEN ALL OF THIS..
- BOLTED UP THE NEW MOUNT AND INSTALLED THE FAN.. I ALSO WENT OUT TO LOWES AGAIN TO GET NEW BOLTS FOR THE MOUNT. THIS CAR WAS MISSING SOO MANY SCREWS AND BOLTS BUT THESE BOLTED UP NICELY..
- FINALLY GOT THE WHEELS ON AND PUT THE CAR ON THE GROUND..
- LAST I WENT TO PUT ON THE NEW ALTERNATOR HOWEVER THE SELLER SENT ME THE WRONG ONE... THE OLD ONE WAS WORKING SO I JUST DECIDED TO SENT THE NEW ONE BACK AND USE THE ONE I HAD...
  #82
Old 01-13-2016, 08:02 PM
Grip Grip's Avatar
Grip Grip
Grip Grip is offline
Wow, nice work on your project. I wish I had half your energy and a 1/4 your ability.
  #83
Old 01-14-2016, 07:57 AM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
When that bolt snapped , I was like arrgghhh . Glad it tapped out.
  #84
Old 01-16-2016, 05:26 PM
MazMini's Avatar
MazMini
MazMini is offline
- FIRST UP ON TONIGHTS LITTLE LIST WAS TO GET THAT WEIRD WATER LINE INSTALLED. ONCE THAT GOT BOLTED UP i WAS ABLE TO INSTALL THE THERMOSTAT AND THERMOSTAT HOUSING.
- NEXT WAS THE HUGE WATER HOSE THAT RUNS FROM THE THERMOSTAT TO THE ELBOW BY THE ALTERNATOR.
- I GOT THE AC COMPRESSOR OUT OF THE BOX AND DECIDED TO PUT SOME OIL IN IT BEFORE INSTALLING IT. ONCE OILED UP i INSTALLED IT AND THAT WAS THAT...
- LASTLY I WENT TO INSTALL THE MANIFOLD GOT IT MOUNTED AND ALL.. HOWEVER I CANNOT FIND THE BOLTS IN MY MAZE OF PARTS AND ZIP LOCK BAGS WITH STUFF IN THEM.. SOO TOMORROW THIS SHOULD BE DONE..
ALMOST TIME FOR IT TO START!!!!!!!!!!!!!!
  #85
Old 01-18-2016, 08:11 AM
Excited, getting closer. Cant find the bolts in the end let me know. 07131500899/
M8X35MM size
https://www.ecstuning.com/Search/Sit...h/07131500899/
  #86
Old 01-18-2016, 04:52 PM
MazMini's Avatar
MazMini
MazMini is offline
M8X35MM size
I found them in a bag all by themselves... lol
  #87
Old 01-19-2016, 06:23 AM
ok , thats great. Thought they were gone.
  #88
Old 02-24-2016, 09:49 AM
MazMini's Avatar
MazMini
MazMini is offline
Its been a looooooooooooooong time!!
WOW !!! Its been a while since i have updated and even touched this car.. Started a new job and new school semester and before you know it I was far behind... Couple new updates:
- Installed the new Intake... Now the reason for this was because the OEM Air Cleaner assembly was destroyed in the accident. I didn't want to pay $200.00 for a new one so I ordered a Ebay kit.. (PAIN IN THE REAR) it needed a little modifications but it fit.
- JUMPED ON EBAY LOOKING FOR NEW HOODS AND FOUND A USED COOPER S HOOD FOR 250.00 WITH EVERYTHING. ONLY CATCH?? I HAD TO DRIVE TO NORTH CAROLINA TO GET IT. WE MADE IT INTO A WEEKEND TRIP AND PICKED IT UP.
- I WENT TO START THE CAR AND IT DID NOT FIRE.. WELL FIRST THING WAS MAYBE ITS NOT GETTING FUEL.. I WAS CORRECT THE FUEL PUMP WAS NOT SENDING FUEL TO THE FUEL RAIL. I ENDED UP TAKING OUT THE FUEL PUMP AND ORDERED A NEW ONE. SHOULD BE INSTALLED THIS WEEKEND.
- ORDERED SOME NEW HEADLIGHTS AND THE REST OF THE REMAINING PARTS. NOW ITS TIME TO FINISH UP AND GET THIS THING PAINTED.. SHOULD HAVE SOME MORE UPDATES WITHIN THE NEXT WEEK..
  #89
Old 02-24-2016, 09:53 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Glad you hopefully figured out the no start issue.
888.280.7799 | 6am - 5pm PST
  #90
Old 02-24-2016, 10:42 AM
Well done, looks pretty awesome as a roads racer like that.
  #91
Old 03-28-2016, 04:59 AM
MazMini's Avatar
MazMini
MazMini is offline
Its been a while!!!!!
WOW!! ITS BEEN A WHILE SINCE I TOUCHED THIS CAR BUT HERE ARE SOME UPDATES. I WENT BACK OUT INTO THE GARAGE AND SPENT ABOUT 4 HOURS ON THE CAR ..
- FIRST I GOT THE HOOD FITTED AND RAN THE ELECTRICAL UNDER THE HOOD. STILL HAVE TO DO THE PLUMBING FOR THE WINDOW WASHERS..
- NEXT I FITTED THE WHEEL WELLS AND ASSEMBLED THE FAN, RADIATOR AND CONDENSER TO THE MAIN SUPPORT AND DID A TEST FIT.... MADE SURE IT CLEARED EVERYTHING.
  #92
Old 03-28-2016, 01:28 PM
Wow its like a throw back to the production line. Looking good.
  #93
Old 03-31-2016, 05:10 AM
Passatrs4's Avatar
Passatrs4
Passatrs4 is offline
Great Job on the rebuild. This post has me glued to my computer for the past couple of days. can't wait for the next post.
  #94
Old 03-31-2016, 07:25 AM
I know, me too.
  #95
Old 04-01-2016, 07:54 AM
MazMini's Avatar
MazMini
MazMini is offline
Almost Done!!!!!!!!!
EXCITING TIMES AS IT COMES DOWN TO THE END.... !! LETS GET TO SOME UPDATES..
- RAN THE FAN WIRE LOOM AND USED SOME HOME DEPOT SPECIAL TO KEEP IT ALL NICE AND TIDY..
- CONNECTED UP THE RADIATOR HOSES TOP AND BOTTOM
- FITTED THE FRONT CRASH BAR AND WAITING FOR COUPLE NUTS TO COME IN....
NEXT UP TEST FITTING THE BUMPER AND INSTALLING THE HEADLIGHTS AND WINDSHIELD WASHERS AND PLUMBING FOR THE WASHERS..
  #96
Old 04-01-2016, 07:56 AM
PelicanParts.com
Vendor
The light at the end of the tunnel! So close.
  #97
Old 04-01-2016, 01:54 PM
MazMini's Avatar
MazMini
MazMini is offline
yes!!! Cant wait!
  #98
Old 04-03-2016, 11:49 AM
MazMini's Avatar
MazMini
MazMini is offline
Lights Lights Lights!!!!
LIGHTS LIGHTS LIGHTS
- INSTALLED THE HEADLIGHTS WITH THE HID KIT
DEPOT HEADLIGHTS WITH A 6K HID KIT
TEST FITTED THE HID KIT IN THE ONE GOOD FOG LIGHT I HAD.. (WAITING ON THE NEW DRIVERS SIDE TO COME IN)..
  #99
Old 04-06-2016, 07:57 AM
MazMini's Avatar
MazMini
MazMini is offline
- AFTER THE ACCIDENT I NOTICED THE WIPE ARM BROKE OFF AND I FINALLY GOT AROUND TO INSTALLING THE NEW ARM.
- FINALLY WANTED TO DO A TEST FIT WITH THE BUMPER AND THE HOOD.. STILL WAITING ON A FEW PARTS (BUMPER LIGHTS AND FOG LIGHTS AND BRAKE VACUUM LINES) BUT SO FAR SOO GOOD HAD TO TAKE THE HEADLIGHTS OUT TO INSTALL THE HID KITS.. THIS CAR HAS MORE COLORS THAN ANYTHING ELSE ON THE STREET.. IM ABOUT A WEEK AWAY FROM DRIVING IT ON THE STREET!!!!!
  #100
Old 04-06-2016, 09:08 AM
Nice , , its a little multiple color right now but its taking shape.
Quick Reply: R50/53 R50 Cooper Rebuild Let the Fun Begin! :popcorn:
