R50/53 Supercharger Belt
Old Jun 28, 2015 | 02:13 PM
mini yellow-haa!'s Avatar
mini yellow-haa!
Supercharger Belt
Hey Mini Gang!, YellowHA here. Just a quick question, I'm going to do my first belt tensioner replacement (diy). I have M7 16% pulley, also alta crank pulley not sure the size . the part in question is the drive belt. I'm considering buying the belt in my local store. Can I use the standard? Thanks Gang!.
Old Jun 28, 2015 | 03:16 PM
ZippyNH's Avatar
ZippyNH
Nobody can answer that question unless you find out if the alta crank damper stock or oversized...
A 535 length belt should be fine if the crank damper is stock....a 532 is used by many with the 17%, but that might be too tight with a 16%....both belts are common sizes, and at about $20 locally, not a big deal to find...m7 pulies DID varry in size lots..some were bigger than 15% some smaller than 17%..quality issues for years..
The stock 1388 mm length belt (not sure about the as equivalent but know it would be 1390mm) is too long with a pulley...it will be OK for a few months, then slip..lots, even at higher rpm when new....
All bets are off about length if you find the crank damper is nonstandard...
Old Jun 28, 2015 | 03:45 PM
808R53's Avatar
808R53
When I bought my 15% pulley package at Way Motor works I was given Gates micro-V KO60535
I'm also running a ATI 2% super damper crank pulley.
You could also go with: Napa- 060535
Gatorback 4060537- Got this one from Hawaii import parts
Did a search on this lots of positive, people like the (whining sound) and they say it last longer.
Old Jun 28, 2015 | 04:00 PM
mini yellow-haa!
That was a ZIPPY quick reply. Thanks Zip. The previous owner gave me this alta box with the old damper in it. though on the box I can see he wrote 2 and next to it is a faded marking which I believe is a % symbol. Now, I'm leaning that the one I have in the mini is indeed a 2% lightened crank pulley.
So my question will go on with this info. M7=16%, Alta=2% damper. Brand belt size= _____? Thanks again Gang! YellowHA.
Old Jun 28, 2015 | 04:23 PM
mini yellow-haa!
Thanks 808, Aloha to you brotha! Given that my SC pulley is 16% and have the same damper crank pulley size. I'm not sure If a 1% difference have a big deal using those part#. Hmm should be no problem.
Old Jun 29, 2015 | 10:33 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have a good DIY with some info in regards to the upgrade as well here.
-Luccia
888.280.7799 | 6am - 5pm PST
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
Greezyman
19
Sep 28, 2015 12:04 PM
Emnotek
Sep 11, 2015 04:16 PM
