R50/53 Tranny/LEAK Spongy Clutch Help.
Old Jun 2, 2015 | 02:34 PM
BamaR53's Avatar
BamaR53
2005 R53 6-Speed, petal has recently becoming spongy and soft after what MY son describes as a loud hissing sound. Upon test drive, the tranny and clutch appear to be perfectly operational other than than the soft clutch and a rattle on clutch actuation at a very high RPM (which sounds very much like a Throw out bearing) I was thinking this light rattle may be due to lack of pressure on the clutch system. I am sure it is time for a clutch set, but can u explain the soft petal and the odd hissing sound at the time of malfunction?
The really scary issue is I noticed an odd fluid leak from a small hole at the very bottom of the tranny/engine assy where the two meet. I have heard of catastrophic TB failures that puncture (please say that is not it), but everything works..lol..just not well.
Any help or advice is welcome.
Old Jun 3, 2015 | 01:26 PM
louie12345's Avatar
louie12345
fluid coming from the little hole could be engine oil leak from rear main seal. how many miles you mini have? spongy feel could a broken clutch release fork. It happened to someone recently. he tried bleeding the system with no result. Took the tranny out and found out it was a broken fork. You could tried bleeding the system to start to see it helps. There is a right way to do it. do a search.
Sep 23, 2015 12:59 PM
Sep 23, 2015 12:52 PM
Sep 23, 2015 12:39 PM
Sep 22, 2015 02:05 PM
Colt45Magnus
Sep 16, 2015 11:15 AM
