R50/53 Alta filter desintegrating
Old May 16, 2015 | 10:19 AM
Lt. Dan's Avatar
Lt. Dan
So I went to clean the foam filter on my Alta CAI today, and found the foam filter was coming apart, and actually had started separating at the seam! What good is a filter if it isn't "filtering"... LOL
So, has anybody found a suitable replacement filter for the Alta Intake? I have a speed shop near me that stocks Spectre filters, and was thinking about trying one of those...
Old May 16, 2015 | 10:41 AM
Capt_bj's Avatar
Capt_bj
did you call them about a replacement part?
I'm pretty sure a friend of mine had the issue and ALTA was very helpful at minimal cost . . .
Old May 16, 2015 | 11:03 AM
Lt. Dan's Avatar
Lt. Dan
No l'm not the original owner, and the intake was installed when I got it. I also believe it probably failed due to lack of maintenance since my red filter was black and clogged with crap...
Old May 16, 2015 | 04:58 PM
buzzsaw's Avatar
buzzsaw
I took the dimensions from the JCW air filter and cross referenced that with the Amsoil nano filter and have been very pleased the last seven years. It definately breathes better at high altitudes. It's easy to clean, very durable and reasonably priced. Figured since that filter technology is used on the turbine engine of an Abrams tank, should be good enough for our R53. Good luck.
Old May 17, 2015 | 08:10 PM
jamez's Avatar
jamez
+2 on the Amsoil (reusable non-oiled) blue filter. I have one for both my JCW's
I just took an Alta out of the new(er) JCW and it was falling apart and not cleaned.
Old May 17, 2015 | 10:23 PM
ZippyNH's Avatar
ZippyNH
When the wrong oil is used on servicing foam filters. It can destroy the foam...
Folks often use K&N OIL on a foam filter....it destroys them....
Buy a new filter....problem solved...oh..and BUY the RIGHT servicing kit!!
Old May 18, 2015 | 12:20 PM
We have the Pipercross version filters and must use the pipercross cleaner and light oil. Sounds like wrong filter / cleaner over the years.
bahman
Nov 15, 2019 05:45 AM
rtk90
Aug 29, 2019 09:08 AM
Mb460
Sep 14, 2015 05:50 AM
Emnotek
Sep 11, 2015 04:16 PM
Sep 10, 2015 11:55 AM
