Howdee -
I happen to have rust developing behind this seal. How can I remove it without damaging to paint. I intend to use the old seal after the paint job.
Anyone have any experience with this?
Mike
Mike
Moderator
At 15 bucks a side.....and being as old as they are just pull them off and replace.
5) 51337050534 GASKET BETWEEN DOOR AND ENTRANCE FRONT $14.97
How do they come off? You didn't answer my question. Do they glue on?
If I have to replace them I will, I'd like to know how to properly remove them...
Moderator
Been a while since I have had a set in front of me but I believe they are white push pins as depicted in the image I posted either # 9 or 11.
Ok thanks, ultimately I'd crawl underneath tomorrow and take a look. I looked underneath briefly today, but didn't notice anything that "stuck out" as the obvious thing!
close
- Join DateJan 2013
- LocationWadsworth, Ohio
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:2,537 Times in 2,245 Posts
Its has long snap that snap into small slits on the bottom. Its not that hard to take out , just pull on them a bit from the end , then line the new on up and push in way , new ones to put in are a little tight , just press firm with your thumb. Using the old one watch for rust on these on the end. Also they have a metal core , so if you pull them too hard they can kink up and then you have to bend them back straight. I just replaced mine.
#5 One for each front door ( Gen 1 MINIs. )
http://www.ecstuning.com/Search/SiteSearch/51337050534/
