R50/53 R53 supercharger noise. Bad?
Old Mar 22, 2014 | 11:58 AM
Hillis24's Avatar
Hillis24
Loud mechanical rattle when cold, and not as loud when warm. No loss of boost or increase in water temp. 135k in the odometer and I have owned it since 85k miles.
Old Mar 22, 2014 | 04:42 PM
captainslow's Avatar
captainslow
how many miles are on the car? definitely seems as though the S/C is giving up the ghost..
Old Mar 23, 2014 | 01:33 PM
BRG's Avatar
BRG
Thanks for the video. I tend to think it is the SC.
Did you eliminate the adjusting pulley as the culprit ?
I just replaced my belt tensioner and separate adjusting pulley which cleared up two sounds. 1 - whirring noise ( tensioner pulley ) 2 - shrill whistle ( adjusting pulley )
Neither of them sound like the rattle you have.
Old Mar 23, 2014 | 02:06 PM
Hillis24's Avatar
Hillis24
130,000 on sc now.
Yes, everything is silent except sc. The bushing stopped the noise I had when taking off from stop with rpms below 2k.
I'm going to spend a chunk and get a new sc, tpr2t head, cam , header, exhaust and some other bits with a tune. If I'm doing one might as well do it all at once.
Old Mar 25, 2014 | 06:41 PM
Husam Hammadi's Avatar
Husam Hammadi
I have the same ticking noise that you hear when you took off the belt, is that normal??
Also, i can kinda hear the same noise when using a stethoscope on my SC :( hopefully not going out soon (110k on it, oil was full when replaced last year)
When you do happen to replace it, can you post here if you found any oil left in the SC?
Thanks.
Old Mar 25, 2014 | 07:01 PM
Lemoneminems's Avatar
Lemoneminems
Mine started to make the same noise the other day and did some research. Looked like the most common cause was the timing chain tensioner so I replaced it, but no luck. Took it to a specialist and it turned out to be the supercharger. The repair came out to ~$2,800 to replace the supercharger, timing chain, and valve cover gasket. Worst part is the supercharger has to be ordered from Germany and is going to take 7-12 business days to ship =(
sevin
May 2, 2026 06:11 AM
Finhead
105
Aug 14, 2023 07:51 AM
Melvinyip
Apr 17, 2020 09:28 AM
tacticalbacon02
Aug 22, 2015 06:05 PM
elightbo
Aug 17, 2015 01:50 PM
