R50/53 Headlights acting up
Old Nov 5, 2013 | 08:02 AM
AustinDave66's Avatar
AustinDave66
Hello all, I have a 03s that recently went through some fairly high water. Ever since then one headlight only works on high beam and the other only works on normal beam. I have swapped both sets of bulbs and the same thing happens. Any ideas or help would be greatly appreciated. Please lett me know if more information is needed.
Thanks,
David
Old Nov 5, 2013 | 08:07 AM
spidertnt's Avatar
spidertnt
Check BC1 connections x332
http://www.minitorque.com/forum/f26/...trol-unit-557/
MINI Cooper BC1 connections
Connectors:
X332 20 pin green "A"
X332
Pin-Description-Connects to/from
1 Terminal 30 Fuse F37
2 Passenger window open Passenger door window motor
3 Terminal 30 Fuse F1
4 Passenger window closed Passenger door window motor
5 Ground Chassis ground
6 Driver window open Driver door window motor
7 Terminal 30 Fuse F19
8 Driver window closed Driver door window motor
9 Left high beam Left headlight
10 Ground Chassis ground
11 Ground Chassis ground
12 (not used)
13 Right high beam Right headlight
14 Terminal 30 Fuse F14
15 Left low beam Left headlight
16 (not used)
17 Terminal 30 Fuse FL12
18 (not used)
19 Right low beam Right headlight
20 Terminal 30 Fuse FL8
Old Nov 5, 2013 | 11:53 AM
ZippyNH's Avatar
ZippyNH
Xenon or halogen headlights?
Old Nov 5, 2013 | 12:47 PM
AustinDave66
Xenon
OutMotoring
Mar 3, 2017 06:29 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
