R50/53 2006 Mini Cooper Trans. into 2002 Mini Cooper
Old May 7, 2013 | 03:01 PM
Snakebitx1's Avatar
Snakebitx1
What is the difference between the two transmissions besides gear ratios? Will the 2006 mini cooper transmission work with the 2002?
Here are the two VIN's if it helps:
2006:
WMWRC33536TK72649
2002:
WMWRC33472TC37715
Old May 7, 2013 | 04:48 PM
Braminator's Avatar
Braminator
They changed it from a Midlands 5 speed to a Getrag 5 speed.
Old May 8, 2013 | 04:34 AM
Snakebitx1's Avatar
Snakebitx1
I believe both card are 5 speeds not 6.
Old May 8, 2013 | 05:04 AM
Braminator's Avatar
Braminator
You could always change it to the 6spd Getrag like in the Cooper S if you are having problems.
See this http://personal.stevens.edu/~jdunn/F...heWeakLink.pdf
Check this thread out.
http://forum.minicooper.org/showthread.php?t=9643
Old May 8, 2013 | 06:57 AM
ZippyNH's Avatar
ZippyNH
I know the cv joints/axels are different on a cooper with the midlands vs the getreg....number og splines are different....so more involved than just a tranny swap.
Old May 8, 2013 | 10:01 AM
Snakebitx1's Avatar
Snakebitx1
I'm just trying to find out if a guy with an 02' will be able to swap in my 06 tranny. I don't need to know my upgrade options.
Old May 8, 2013 | 12:04 PM
ASKtheteach's Avatar
ASKtheteach
From 2002-2006, the non-S Cooper had a 5 speed transmission (Midlands at first, Getrag later). The Cooper S had a 6 speed. With automatic, the non-S had a CVT transmission that was prone to spectacular failure, and the S had a standard 6 speed auto.
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 10, 2015 02:03 PM
joelcseymour
Aug 7, 2015 12:43 PM
