R50/53 Pre-loading suspension then tightening after sub frame removal
Old Feb 12, 2013 | 09:08 PM
Grahams315's Avatar
Grahams315
Hey guys. I'm getting ready to overall to pull my sub frame and overall my bushings and I have a quick question. From what I've read on most cars it seems that after everything is bolted and torqued, some bolts (outer ball joint?) need to be loosened and re-torqued after the car has been lowered.
Does anyone have experience with this relating to exactly what bolts need this treatment or any other tips. Thanks!
Old Feb 13, 2013 | 12:33 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
In general rubber bushes have to be tightened when loaded so they flex from a neutral the same amount each way. Lower the car - final tighten the bushes. You can lower it onto 4 cut down rail sleepers to give you height.
Old Feb 13, 2013 | 03:48 PM
Grahams315's Avatar
Grahams315
Thanks. I'm assuming then ill need to do this with the inner and outer ball joints and the outer tie rod end?
maestro39
Oct 27, 2015 02:38 PM
ltjpunk7
Sep 6, 2015 07:32 AM
greekzilla
Aug 23, 2015 03:44 PM
Emnotek
Aug 13, 2015 05:47 PM
