R50/53 Haunted Mini
Old Jan 17, 2013 | 03:52 PM
gbo3's Avatar
gbo3
Haunted Mini
Had a very weird thing happen with my 04 S yesterday.
I drove to where I was working for the day, temp was around 12 degrees F.
so my windows were up.
Parked at a metered space unloaded my gear and headed out. Came back around noon and fed the meter. I didn't notice anything unusual.
Finished up my day, came back to the car, popped open the hatch tossed my gear in. Started to unlock the drivers side door with the key since my auto lock doesn't work. Just then I notice the window is down about 4 inches, the passenger window is down the same and my sun roof is open about 4 inches.
F---ing weird, I was sure everything would be missing. Nope. All fine.
I know the windows were closed when I left, to darn cold to be open. I can't think of anything I did to open everything the same amount.
Anybody had this happen? Is my car messing with my head? Is this the beginning of other weird stuff?
Old Jan 17, 2013 | 08:24 PM
Kdelder's Avatar
Kdelder
Your car has a feature when you press and hold the unlock button for 2 or more seconds it rolls down the windows and opens the sunroof. Mainly used for hot weather to allow the hot air to escape before entering the car. I find that if I press my unlock button in rapid succession to get everything unlocked it starts this program. Nothing to worry about just a minor quirk of owning a Mini.
Old Jan 17, 2013 | 08:34 PM
gbo3's Avatar
gbo3
Kdelder
Thanks, I guess I didn't realize that. I must have mashed down the key while loading the trunk
nice to know !
learned something new
Old Jan 19, 2013 | 05:30 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
It is in the hand book.
Old Jan 19, 2013 | 06:24 AM
mothyray's Avatar
mothyray
My friends always think I have a team of trained Gerbils running a tight rope act when I do this. I just explain nope that is just how cool MINI is.
Old Jan 19, 2013 | 12:19 PM
gbo3's Avatar
gbo3
mothyray,
tis cool, now that I know.
little car was freaking me out.
MINIFatherFigure,
handbooks are cool when you have one. But I knew the answer could be found here.
Old Jan 19, 2013 | 04:09 PM
MINIFatherFigure
I had to buy hand books for two of my fleet off e-bay. Best money I spent.
Old Jan 19, 2013 | 04:12 PM
gbo3's Avatar
gbo3
ok, after 5 years of ownership, I guess I should get one.
Old Jan 19, 2013 | 05:45 PM
MINIFatherFigure
Try specialist wreckers too - often books are left in the car. My wrecker pulls them and keeps them in the office.
Old Jan 19, 2013 | 05:53 PM
Englshmn's Avatar
Englshmn
Same thing happened to me when I first got my Mini. I just wish there was a way to put the windows back up!
Old Jan 19, 2013 | 11:29 PM
ZippyNH's Avatar
ZippyNH
A quick search will get you one in PDF form for free online..several years are around...the MINI website had a few gen1's up for a bit...
Old Jan 20, 2013 | 01:27 PM
kedwards's Avatar
kedwards
Though you are probably referring to the remote control button, you can use the key in the lock to activate the convenience closing feature (as mentioned in the Owners Manual).
Also, the convenience opening feature can be activated/deactivated by the dealer. My 2003 has it active, but my wife's 2004 does not. Neither one has a sunroof, so it is less of an issue.
Keith
Old Jan 20, 2013 | 07:57 PM
MINIFatherFigure
A cheap TEMPORARY fix for R50 body cars with windows not going down -Thump the door at about the 10-11 o'clock position on the big oval trim ring while flicking the switch to the down position. (Dealer trick and it works!!)
Old Jan 24, 2013 | 06:32 AM
Kdelder's Avatar
Kdelder
I think there is a module that you can get from FES Auto that allows you to press and hold the lock button on the remote to close the windows and sunroof.
EDIT: The module is from outmotoring.com. It is supposed to be compatible with the Ian Cull Circuit as well.
Old Jan 24, 2013 | 06:58 AM
USCooper's Avatar
USCooper
LOL I love the idea of it being haunted. "The spirit wanted to escape but also wanted options- passenger window, driver's window...or sunroof?"
I've noticed something strange too- if I lock my car and then unlock the boot (usually like at the airport to get my luggage out) sometime while I'm gone the other doors unlock as well. Kind of creeped me out. I have to unlock the doors again and lock them to prevent this from happening. Anyone else experience that?
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
