R50/53 03 mini cooper s
Old Dec 9, 2012 | 12:40 AM
caboose's Avatar
caboose
03 mini cooper s
What is considered fair or market price for a partial picked over S with bad motor, broke rod, supposed good getrag...? Interior is good. Really all I need is the manual trans to convert my cvt. The S cant b rebuilt, roof is gone and other front panels. subframe is good as is supercharger. & wires and computer are there.
Can I put supercharger on my normally aspirated engine?
I guess it boils down to how much of the s I should haul to the scrap yard if it ain't worth foolin with.
Old Dec 9, 2012 | 03:34 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
IMO if you want to convert to an S, better to start out with one.
Cooling system is entirely different not to mention the engine management systems between a Cooper and S are not the same....
Old Dec 9, 2012 | 05:13 AM
Pure87's Avatar
Pure87
You can convert to an S, but it's not worth the time, money, or effort. It's more than swapping body panels and adding a supercharger. A lot of things are arranged differently, so you'll have an issue with adding components. Google around for a bit to see some methods. It's a very involved process.
Old Dec 9, 2012 | 06:05 AM
caboose's Avatar
caboose
To clarify, my main objective is to replace the dead cvt auto trans The getrag requires the shifter and linkage, the pedle aassembly, brackets, flywheel & clutch assembly. .My 2003 na motor is fine (if gutless) but the s is a donor car at $2500 that cannot be rebuilt. so I will have many S parts left over.
Old Dec 9, 2012 | 07:27 PM
SniperDetailing's Avatar
SniperDetailing
I'd say off them $2K, but even at $2500 it's still a bargain because you would probably spend about $2K just piecing everything together separately and you can easily make that $500 and more back by selling the S engine and supercharger along with anything else included with the car.
Old Dec 9, 2012 | 07:45 PM
caboose's Avatar
caboose
thanks sniper, I think I will get a second damaged hood, a second set of wheels and a rebuildable supercharger. Surprised the s charger needs rebuild, what is the life expectancy of such?
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
