R50/53 Squeaking noise when turning at low speed
Old Jul 23, 2012 | 06:06 PM
Kahnfucious's Avatar
Kahnfucious
Hey guys
Any thoughts on what it might be -- getting a squeaking noise while taking sharp turns at low speed...
Thoughts on the cause and/or cost to repair?
Old Nov 4, 2012 | 04:48 PM
Kate in the Middle's Avatar
Kate in the Middle
Hi did you find out what your noise was when turning? My new to me '09 Cooper S has a high pitched squeak when turning slowly only to the right. Is not brakes but has that type of sound.
Old Nov 4, 2012 | 04:50 PM
Kahnfucious
I didn't if was a car I was looking at but didn't buy....my guess would be wheel bearing...sorry.
Old Nov 4, 2012 | 05:03 PM
sgabela's Avatar
sgabela
Not all the squeaking noises are the same, mine ( R53 ) was the steering rack, make sure that the oil level is right. Also it might need an alignment. that is the easy part, I will try that first. if not to the shop.
Old Nov 4, 2012 | 06:11 PM
InTheClub's Avatar
InTheClub
My car had the same problem this summer. It turned out the caliper bolts were bent. It took me taking it to the shop 2x before they figured it out. When I turned the corner slowly, it would sound like I was dragging a metal pipe along.
It could be wheel bearings as well. I'd get them to inspect your brakes/calipers/pads/etc.
Old Nov 8, 2012 | 12:04 PM
user 7263's Avatar
user 7263
Anyone have this same experience, but with more of a rubbing sound than squeaking?
eliseo1981
Jan 28, 2021 02:45 PM
silence2-38554
Nov 12, 2015 09:39 AM
maestro39
Oct 27, 2015 02:38 PM
David.R53
Sep 1, 2015 06:51 PM
