R50/53 Lower control arm help!!!
What HRM said. You will want to insert your socket in the big hole on the subframe first. Once it's sitting on the bolt, connect your ratchet to the socket. If it still won't fit, you may need to hit up your local sears tools department. The socket will need to be long enough so that it doesn't sink too much in the subframe that your ratchet can't connect to it and if you have a bulky ratchet, you may want to look for one with a flatter head.
BRracing
Dec 22, 2015 09:25 AM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
