R50/53 Will a MCS run without the SC belt on?
Old Oct 10, 2011 | 06:04 PM
r3l3ntl355's Avatar
r3l3ntl355
Trying to diagnose a rattle between the timing set and the SC. If I took the belt off of the SC and started the car and the rattle was still there then I would imagine it would be the timing set. Is my thinking correct here, and will the car run with that belt off?
Thanks for any insight!
Old Oct 10, 2011 | 06:24 PM
ZippyNH's Avatar
ZippyNH
The waterpump is run off the sc....
So it may run for a few moments...but will get hot fast...so be careful, you don't want to get it hot, and need a headgasket...
Try using a mechanics stechscope? Harbourfreight has them cheap....
A stick touching the area you think may be making the noise , and held tou your ear might also work to narrowdown the area...
Old Oct 10, 2011 | 06:29 PM
r3l3ntl355's Avatar
r3l3ntl355
I didnt think about the stethoscope, Ill try and swing by Harbor Freight. I have used a piece of heater hose in the same way to find bad lifters and exhaust leaks. I would imagine it would only need to run for a second, just long enough to hear the noise.
Old Oct 10, 2011 | 07:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You can run it for just a little bit, but it will overheat after about a minute, and you will get a battery light cause the Alt won't be turning.
Old Oct 11, 2011 | 08:54 AM
quikmni's Avatar
quikmni
At long screw driver, with your ear on the handle, also works well to listen to noises but not as safe as using the stethoscope.
iamcamkeenan
Aug 10, 2015 03:31 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
