R50/53 Mobil 1 0W 40
Old Aug 26, 2011 | 02:18 PM
  #26
wma1887's Avatar
wma1887
Has anyone tried the Valvoline product?
Valvoline VV955 SynPower Motor Oil SAE 5W-30, Pack of Six 1 Quart Bottles
Amazon has a great deal on it if you sign up for regular shipments (monthly, quarterly, or six months) but I don't want to sign up for it if it isn't wonderful.
I kind of like the idea of 6 new bottles showing up every 6 months to remind me to change my oil, and at just over $6 a quart, that is really cheap for a good synthetic oil.
Old Aug 26, 2011 | 04:20 PM
  #27
Cadenza's Avatar
Cadenza
Originally Posted by mikewitdaspike
You guys are making me feel bad about using Castrol Syntec 10w30 I figure since I'm in Phoenix, AZ, and it's over 90* even at like 3am, gets over 115* during the day
I would go to 0w-40 or 5w-40 grade for Phoenix heat.
Old Aug 26, 2011 | 06:52 PM
  #28
mikewitdaspike's Avatar
mikewitdaspike
seriously? that's so thin though
Old Aug 26, 2011 | 07:38 PM
  #29
BlwnAway's Avatar
BlwnAway
, heavier than the factory spec.
Old Aug 26, 2011 | 07:44 PM
  #30
mikewitdaspike
referring to the 0w part, the 40 part is heavier than I would have expected. It's gone about 1,000 miles on the current oil change, and by the time it's due another one the car will be back in Kentucky, so I guess I'll just have my wife put 5w30 in it then
Old Aug 26, 2011 | 10:15 PM
  #31
Michael Lewis's Avatar
Michael Lewis
I think I'll listen to the mates that made our cars and stick with 5w30.
On the other hand. . . I wonder what oil xsmini uses. Last I saw on here there was 262k miles on that 03 MINI Cooper S. We should all probly take after that guy!
Old Aug 27, 2011 | 03:35 AM
  #32
BlwnAway's Avatar
BlwnAway
Like I said in my earlier post, (I know it was a little wordy) the -w grade only has to do with flow rate @ ambient temp. you lose that in a matter of min.
Old Aug 27, 2011 | 06:38 AM
  #33
ZippyNH's Avatar
ZippyNH
Yup
10w oils are pretty much gone and not reccomended in modern motors...
The passages are sized to let the initial pumped oil flow to the bearings quick...so 5w or even 0w is now recommended, and the second spec mini recommends either a 30 or a 40 weight....
The op's Mobil 1 0w-40 is is some ways the most common massmarket oil letting mini specs....
So nothing wrong with it...better than many other oils around imo.
Old Aug 27, 2011 | 07:37 AM
  #34
Minian's Avatar
Minian
Originally Posted by Rayanmx
I'm about to reach 80k and I see the Castrol logo embedded on the supercharger plastic grille and on manual (I'll go with synthetic), so that's what I'm using, but:
What's the recommended oil weight for that mileage and California weather?
Some say it's supposed to be 10W40, is that right?
If you have an R53 you should use 5w30 Full synthetic. (Euro Formula is best)
Mobile 1's 0w40 is very good, but so is there 5w30. I've change my own oil since 2003 and found no outstanding difference.
If you have an R56 go with the Mobil 1 0w40 Euro or something equal or better. Don't Get Cheap with a Turbo, also those of you that are waiting until 15k miles or more to change your oil are going to have problems sooner than you think. Of course it depends on driving style and milage.
As for the 10w xx huh, put that in your truck! A MINI doesn't deserve that kind of neglect (Just my $.02)
Old Aug 27, 2011 | 05:20 PM
  #35
Cadenza's Avatar
Cadenza
Forget the blokes, I would rather pay attention to the Krauts...
Owner's Manual (p.115)...
The correct SAE grade for your Mini is determined by the climatic conditions of the region in which you normally drive your Mini.
Approved oils feature the SAE grades 5w-40 and 5w-30.
Only use oils with a specifications of API SH or higher.
So as long as the oil meets OR exceed these specs, you're fine. API has SM specs now, which is backward compatible.
Once the ambient temp is 90*F+, X-40 grade is better. Don't worry about the winter specs of 0w-xx or 5w-xx, it's good for cold flow and helps prevent wear for the first 10-15 minutes after a cold start.
Old Aug 27, 2011 | 09:01 PM
  #36
unibus_driver's Avatar
unibus_driver
The correct SAE grade for your Mini is determined by the climatic conditions of the region in which you normally drive you Mini.
I think you will have to tell us what year and model of MINI belong to the Owner's Manual you are quoting. Mine (2011 R55 Clubman) does not look like that.
Sorry for reading in the wrong forum.
Old Aug 28, 2011 | 06:16 AM
  #37
ZippyNH's Avatar
ZippyNH
You are in the gen1 forums.....
so gen1 info...gen1 expertise....so r50,r52,r53!!
Old Aug 28, 2011 | 03:50 PM
  #38
Cadenza's Avatar
Cadenza
Thanks Zippy...
Old Sep 6, 2011 | 06:30 AM
  #39
Bravo Zulu's Avatar
Bravo Zulu
Originally Posted by sujeemini
My reactions is based on driving my MCS everyday. At first I was very skeptical about this. As I have never used a 0W grade before. As I was always told that it should only be used in very cold climates.
I'm not saying I'am right, but driving my car day to day and knowing it intuitively, one can tell when there a significant enough differences. This is why sometime when we go to a mechanic to diagnose a problem, they might not be able to feel it. Because you know more about your car since you drive it in day in and day out. And this is very true if you are someone who appreciate's a car for its personality rather than treating it like something that gets you from A to B (unless one is paranoid about the smallest thing that happened in their car ).
But all this discussion has only made me curious to try M1 5W 30 next time!
I did a lot of research on oils before deciding on Mobil 0W-40. It is a standard oil for global use; so it is European formula and is same in US. The oil MINI uses is a special blend Castrol 5W-30 (euro formula) which is very close to Mobil 0W-40. The real key is to use a full synthetic with at least a category IV base stock and meets BMW Long life 1criteria( hence the list previously provided). To merely top off the crankcase you can use anything synthetic like Castrol 5W-30 Edge, Penzoil, Valvoline, etc., but do a full oil change with the ones listed by BMW/MINI.
Old Dec 3, 2011 | 04:45 PM
  #40
HndaShrdr87's Avatar
HndaShrdr87
a lil nugget of info I found out was....no major brand sold in the US is a true "full synthetic", from what i was told/read most major oil brands are a synthetic blend. From what i've heard amsoil is true full synthetic--but it cost an arm and a leg..like $24/qt, now i could be misinformed but the guy at the local auto store was telling me that..i'll get the website with the info and indepedent studies from him on monday.
Old Dec 3, 2011 | 05:42 PM
  #41
kazlot's Avatar
kazlot
Mobil 1 0W 40
Go here: http://www.amsoil.com/catalog.aspx?code=AZOQT-EA
Yes it's full synthetic but you were mis-informed about the price.
For my car I use the Mini branded oil.
Hope this helps...
Old Dec 3, 2011 | 05:58 PM
  #42
MiniKar's Avatar
MiniKar
Which oil you choose to use is you're choice, however don't go 15 K miles between changes.
5 K to 7 K is the maximum amount of miles before the oil starts to break down and I don't want to replace my motor just because Mini says to go 15 K between changes!
Just change the oil & filter as its cheaper than a new motor; and alot less work !
Old Dec 3, 2011 | 10:41 PM
  #43
PatM's Avatar
PatM
Hope this helps...
There are lots of full synthetic motor oils. Mobil 1 is another.
Old Dec 4, 2011 | 01:09 AM
  #44
Cadenza's Avatar
Cadenza
In the US, the term "synthetic" is used loosely due to lack of clear law regulating it. Years ago Castrol began selling synthetic blend as synthetic, Mobil sued them for "misleading" advertising. Unfortunately, the court ruled in Castrol's favor because there's no national law dictating what is synthetic. To better compete, Mobil went on to make a bunch of different oil categories but only Mobil 1 is synthetic.
Simple way to tell is to call up the technical department and ask if the base stock of the oil is Group IV/V. If it's not, then the oil is of the "synthetic" blend variety.
Old Dec 4, 2011 | 07:37 AM
  #45
TimMc's Avatar
TimMc
For anyone thats interested in watching the wear in your engine. Caterpillar sells a oil sample kit at their parts counters. It comes with the sample bottles prepaid postage and they either email or send your results back. Its been a while since I have done it but was less than $15 dollars last time I did.
Old Dec 4, 2011 | 02:25 PM
  #46
kazlot's Avatar
kazlot
Mobil 1 SAE 0W-40
Originally Posted by M3NTAL
This is the MINI Recommended List of Oil
BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market:
  • Castrol Syntec European Formula SAE 0W-30
  • Mobil 1 SAE 0W-40
  • Pennzoil Platinum European Formula Ultra SAE 5W-30
  • Valvoline SynPower SAE 5W-30
I think the idea is to use what the manufacturer (BMW/MINI) recommends.
So that would be either the BMW/MINI branded oil or those listed above.
Hope that helps...
Old Dec 4, 2011 | 02:34 PM
  #47
PatM's Avatar
PatM
Hope that helps...
I always use the Mini oil but if I had to I would use the Mobil oil. That is the saw type I run in my GTO except I use a different weight.
113K on the Goat and I have always used the Mobil 1. I change it when the car tells me to, it has a condition based system as well similar to the Mini, and I drive that car really hard. Still runs like it was new and never had a problem. A high quality pure synthetic oil is good stuff.
Old Dec 4, 2011 | 02:51 PM
  #48
boxter4ever's Avatar
boxter4ever
mobil one is factory fill on all porsche cars.
Old Dec 5, 2011 | 06:15 AM
  #49
Bravo Zulu's Avatar
Bravo Zulu
Hope that helps...
Totally agree with recommendations. The real issue for BMW/MINI is the long life standard. This link explains recommended synthetics and alternatives.
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
For a better understanding of oil go here: http://www.bobistheoilguy.com/
Old Dec 20, 2011 | 10:06 PM
  #50
gsixzero's Avatar
gsixzero
Just my $.02...I use Mobil 1 0w-40 year round in my Mini in Mass with nary a problem. On the other side of the coin I use Amsoil 20w-50 in my Rabbit.
