R50/53 OEM Cupholder rattling after reinstalling
Old Apr 26, 2010 | 09:31 AM
jazztronikk's Avatar
jazztronikk
I took off the OEM cup holder for my 1st generation MINI when I first got it because I thought it was annoying. After awhile I reinstalled the cupholder but because I removed the adhesive the holder makes noises when I'm driving over rough roads. What do you recommend for the holder to be tightly glued to the plastic pillar without damaging any parts? Perhaps liquid cement?
Old Apr 26, 2010 | 09:45 AM
MLPearson79's Avatar
MLPearson79
I would just get some double-sided adhesive tape.
Old Apr 26, 2010 | 10:36 AM
daflake's Avatar
daflake
Mine does the same... If you do get some of the sticky tape make sure that it is not the permanent stuff. That should tighten it up enough to stop the rattle.
Old May 6, 2010 | 01:18 PM
jazztronikk
I used Scotch brand double sided mounting tape. It worked perfectly, no more rattling.
Old May 6, 2010 | 01:29 PM
JumpingJackFlash's Avatar
JumpingJackFlash
Actually, as an alternative to the double-sided tape, perhaps consider a rubber cement solution (unless that's what you meant when you said liquid cement).
Old May 10, 2010 | 06:47 AM
DixonL2's Avatar
DixonL2
Scotch trim mounting tape - the red-backed stuff. Permanent enough, but removable if you really want to, and foamy so it quells the vibration.
ToyCar
Nov 19, 2023 05:20 AM
BernieCoop
Sep 10, 2021 03:15 AM
ej
Nov 17, 2015 09:21 PM
Sc00terbum
Sep 11, 2015 07:17 AM
mikeson
Sep 6, 2015 06:21 AM
