R50/53 Eneos Oil vs Mobil 1 5w30
Old Apr 22, 2010 | 06:33 AM
  #26
03ChiliminiS's Avatar
03ChiliminiS
Mobil 1 spec's http://www.mobil.com/USA-English/Mot...duct_Guide.pdf
Old Apr 22, 2010 | 07:44 AM
  #27
MirthScout's Avatar
MirthScout
Originally Posted by 03ChiliminiS
So, if I understand that chart, these Mobil 1 oils meet Mini specs:
Mobil 1 0w-40
Mobil 1 ESP Formula 5w-30
Old Apr 22, 2010 | 08:12 AM
  #28
ZippyNH's Avatar
ZippyNH
Mobil 1 0w-40
long Life4 is a different approval tha Long-life 1.
Mini Needs Long life 1, (gasoline engines)
Long life 4 is BMW's spec for advanced diesels....so Mobil 1 ESP 5W-30 does NOT meet the spec.
Old Apr 22, 2010 | 08:24 AM
  #29
gaffer's Avatar
gaffer
I've been using synthetic Castrol (US version) 5W30, but I change it more often than the computer says. Question is: Is anybody using the Valvoline SynPower 5W30 that is recommended by MINI as a "long life" oil? Seems like it would be easier to find at a reasonable price than some of the others.
Old Apr 22, 2010 | 01:59 PM
  #30
martinb's Avatar
martinb
If the manufacturer specifies a 5W-30, then that's what should be used. If you second guess either the cold or hot number, you're gambling. Period.
That said, Mobil 1 is still an excellent synthetic. Redline is better. And Amsoil is the best by test. (And no, I'm not an Amsoil dealer.)
Royal Purple is just a mid pack oil and barely so at that (by test).
I run Amsoil in my '06 JCW. And Redline in my motorcycle. And both using the factory recommended weights. Too thin cold and you risk engine damage at start up. Too thick hot and you again risk damage. Stick with the weights recommeded. The engineers aren't idiots.
Old Apr 22, 2010 | 06:44 PM
  #31
03ChiliminiS
The two main anti-wear additives added to the oil are zinc and phosphorus. If you look at the Mobil-1 chart you will see that the GF 4 rated oils all have the lowest level. The reduced levels trade some long term engine wear for better emissions, good for the EPA bad for the MINI's. The 0-40 oil spec for the BMW's has more of the good stuff as do the racing and motorcyle oils. The 0 weight multi vis oils also come from a more highly refined or better base stock.
Old Apr 22, 2010 | 07:44 PM
  #32
kb30's Avatar
kb30
I use 0w40 M1, if anyone else here uses that i was wondering if you have more oil consumption using this oil. i really, really like it and have to say that's the only drawback for me using it.
Old May 11, 2010 | 11:19 PM
  #33
eric loe's Avatar
eric loe
Thank you all for the good input, I have read a lot of stuff about oil and I finally settled with German Castrol 0w-30. There is a sale going on at autozone from may 6 till 31. 5qt GC 0w-30 with bosch filter for $28.
I planned to buy 10 qt which will last me for 15k.
Colt45Magnus
Jul 14, 2019 06:18 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
cawwwtun
May 3, 2016 08:03 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
