R50/53 Battery light on and power steering doesn't work???
Old Nov 26, 2008 | 09:47 AM
diamondwon's Avatar
diamondwon
I have replaced the alternator and had the battery tested ok. 11.8 volts @ the battery with car running or not. That is why i replaced the alternator. Reassembled car and started with the same problem. Battey light on and no power steering. Any help?
Old Nov 26, 2008 | 05:29 PM
healey67's Avatar
healey67
what model mini do you have?? If it is a Cooper S, You may have a bad crank pulley. If the inside of the pulley has seperated from the outside then belt will slip and cause similar complaints to what you are describing.
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
azntaiji
Aug 13, 2015 03:24 PM
xraycat
Aug 12, 2015 02:36 PM
FrostyFox
Aug 12, 2015 02:33 PM
