R50/53 Belt or Pulley Squeal?
Old Aug 24, 2008 | 05:53 AM
TheGermanJob's Avatar
TheGermanJob
I might be a little OCD, but I can't stand my car to make noise! My 2003 Cooper S has been squealing pretty bad, especially when the ambient temp is hot.
Is this a common problem? I saw a couple other posts about this but they didn't really cover any sort of diagnosis/fix. Is it a belt issue or a pulley issue? The car is stock except some intake/exhaust so I don't think it is misalignment. Any help would be appreciated.
Old Aug 24, 2008 | 07:56 AM
Tom D's Avatar
Tom D
If your car has more than 40K on it and the belt has never been changed, start with a belt replacement. There a number of possible causes but the belt is the most likely one.
Old Aug 24, 2008 | 08:30 AM
HighLife4136's Avatar
HighLife4136
+1
Old Aug 24, 2008 | 10:27 AM
TheGermanJob
Alright, I might just have to put a reduced pulley under there when I swap the belt. Thanks.
Old Aug 24, 2008 | 11:14 AM
HighLife4136
Good to see that you're thinking straight!
Old Aug 24, 2008 | 12:39 PM
heyitzsushiboi's Avatar
heyitzsushiboi
along similar lines- i have a 17% sc pulley, 0% crank pulley, and a new belt installed for about 6 months. lately there's some belt chatter/noise. does this happen often? should i replace/tighten the belt?
Old Aug 24, 2008 | 01:03 PM
HighLife4136
You can't tighten the belt. You might want to check the alignment of the pulley...see if one of the fasteners is coming loose. Belt size should be a NAPA 6035. Not sure what the Gatorback size is.
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
makg
Sep 24, 2015 11:10 AM
Emnotek
Sep 11, 2015 04:16 PM
