R50/53 The 'click' sound
No, it has been discussed here what seems forever, the click, usually just one click, like two pool ***** hitting each other when you first move the car, sounds like a CV joint, but it is not constant nor repeatable. A lot of people have it and talk about it, just no one has ever posted that they ever found what it was.
Some think it is a loose axle nut, or hub spline.
Or the CVjoint,
Or in the transmission
Or in the LSD
Or the flywheel.
It is not the brakes
thanks
YD
Or the CVjoint,
Or in the LSD
Or the flywheel.
thanks
YD
I had the problem and it was correctly diagnosed as a loose axle nut (thats helpful...).
I was able to figure out a way to repeat my clicking as much as a I wanted though. Basically you put it into first and rev the engine a bit whilst letting the clutch out (basically doing a hard launch but without the actual launch). Then you do the same thing again except in reverse, when you do it in reverse you get the click. You can also do it in reverse order so it does it while going forward.
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
