R50/53 Strange rubbing sound from rear wheel.
Old Apr 25, 2008 | 07:51 AM
dandw2's Avatar
dandw2
2004 MCS, 44k miles. Stinkin' warranty ran out 26 days ago.
At low speeds we can hear a "rubbing" from the rear left wheel. Has progressively gotten worse. Can anyone relate? I'd hate to think it is a ball bearing, but it is rhythmic.
Old Apr 25, 2008 | 09:00 AM
cycleway4's Avatar
cycleway4
bad/worn wheel bearings will indeed make a rhythmic sound, that increases with speed, and gets worse with time.......
I just replaced a left rear wheel bearing...that could be the problem.
Even though the description doesnt sound like brakes, I'd still want to give them a good look first.
Also, a bad/worn tire, slipped belt,.. can cause a noise driving, that sometimes resembles a bad bearing....and would want to eliminate that possibility.
Steve
Old Apr 25, 2008 | 10:43 AM
dandw2's Avatar
dandw2
Thanks for the info. We notice it mostly under 12mph. We will have to take it to the Mini dealer (just bought it, but it sat for a month afterward) to have a full check done. (Which was supposedly done at the dealer where we bought it ).
May I ask how much it cost for you to have it replaced?
Old Apr 25, 2008 | 11:52 AM
Xymox's Avatar
Xymox
dandw2, take a look here: http://www.mini2.com/forum/mini-coop...l-bearing.html
Old Apr 25, 2008 | 01:07 PM
cycleway4's Avatar
cycleway4
I believe bearing/hub lists for about $200? I paid $139.00 from Above All Motorwerks......
Did it myself.........
Would suspect a dealer might charge 1 hour?.......its about a 30 minute tops job.
Steve
kazyn
Oct 25, 2019 02:34 PM
SosoMINI
Nov 22, 2015 03:17 PM
makg
Aug 21, 2015 02:49 AM
O4mcs
Aug 6, 2015 05:42 AM
