R50/53 Help... looking for a Cooper S
Old Apr 22, 2008 | 02:46 PM
  #26
pmustang's Avatar
pmustang
BTW, thanks for the all the info, must get boring with all the newbies all the time, I very much appreciate the hand holding.
thx. Peter
Old Apr 22, 2008 | 02:48 PM
  #27
ClubmanS's Avatar
ClubmanS
Not a problem! Cheers from Miami!
Old Apr 22, 2008 | 04:19 PM
  #28
NightTrainRob's Avatar
NightTrainRob
Thanks everyone for there input.
Old Apr 22, 2008 | 10:13 PM
  #29
pmustang's Avatar
pmustang
I lived in Orlando for quite a few years near disney.
Peter
Old Apr 23, 2008 | 02:06 PM
  #30
pmustang's Avatar
pmustang
I also have a door lock switch third from the left, forgot that one.
cheers. Peter
Old Apr 23, 2008 | 03:18 PM
  #31
ClubmanS's Avatar
ClubmanS
Yep. The toggle switch panel is the same whether LHD or RHD.
So you are an ex-Floridian eh? Do you miss it?
Old Apr 23, 2008 | 06:14 PM
  #32
NightTrainRob
I have looked at a couple, and I have a question about where the window switches and all are, there is an empty slot on the ones i have looked at, its the 4 one over, has the window, dsc, lock, blank, fog and window.
Whats the blank for?
Old Apr 23, 2008 | 06:58 PM
  #33
ClubmanS's Avatar
ClubmanS
Rear fog is missing.
Old Apr 24, 2008 | 03:40 AM
  #34
NightTrainRob
Rear fog an option on these years? Can you add it?
Old Apr 24, 2008 | 11:12 AM
  #35
ClubmanS's Avatar
ClubmanS
Yes you can. I think the dealer needs to re-program the BCM to enable it and likely install the necessary hardware to support the rear fog lights. What year is your MINI? Rear fog lights became a factory installed option in the 2005 model year.
Old Apr 24, 2008 | 01:18 PM
  #36
NightTrainRob
the one I'm looking at is a 2005
Old Apr 24, 2008 | 01:43 PM
  #37
sequence's Avatar
sequence
only 2005s with build dates of October 2004 and later can be retrofitted with the rear fog, I was told by my dealer. something to do with an incompatibility issue regarding the harness and the wiring leading to the rear, where the BU lite had existed before, and programming the thing to work.
there were a lot of holdovers from the 2002-2004 models in the first three months of 2005 production, july, august, and sept 2004. I could not even add the rfg as an OEM option when I configured and ordered my 2005 S in late june 2004.
stick with October 2004 builds and later and it should not be an issue
Old Apr 24, 2008 | 02:13 PM
  #38
ClubmanS's Avatar
ClubmanS
I got the rear fog light from factory. My R53 S is a February 2005 build.
Old Apr 24, 2008 | 02:14 PM
  #39
ClubmanS's Avatar
ClubmanS
Look at the placard on the driver's side door jamb to find your build date.
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
