R50/53 40K Dealer Check Up
Old Mar 4, 2008 | 03:26 PM
minisystema's Avatar
minisystema
40K Dealer Check Up
Greetings All,
I'm taking my 05 Mini to the dealer for some leaking power steering fluid issues and annoying dashboard ticks, clicks etc. Anything else you might think I should have them check (TSBs, etc.) while it's still under warranty?
Much obliged.
Best,
T.
Old Mar 4, 2008 | 03:52 PM
wvphoto's Avatar
wvphoto
they are notorious for a leaky thermostat housing.. it is plastic and leaks like crazy.. you are lucky if yours has not cracked.. check your blue fluid and make sure you are not low..
aren't these great little cars....!!!!
Old Mar 5, 2008 | 05:02 AM
03BRG's Avatar
03BRG
Brakes but they will not cover it under warranty. Not sure if the 05s had the problem with rust under the door seals they will cover this under warranty!
Old Mar 6, 2008 | 07:33 AM
minisystema
Thanks Guys!
Just took it into Mini of Towson yesterday. They told me the spillage from the power steering reservoir at the fill line is normal and all Minis have that problem. Was told to wipe it down and said the fluid would last a long time before requiring refill. Thermostat housing wasn't cracked. Engine mounts were fine. Rear lower control arms were fine.
Learned my costly BMW/Ipod adapter will not list names of songs for my 05 Cooper. I have a manual stating it should work up to 5 playlists.
Finally silenced the annoying dashboard rattle/creak and wind howling noise at high speed. Rattle came from under center of dash and they added ANYI Creak Kit & insulation pin. Wind noise came from a misaligned driver's side window.
Abnormal wear on right front tire wasn't covered. They explained that the right front pulls the axle therefore it will wear out first. Can't understand why it's only the outer edge that wears. Must be torque steer. Brakes were low but still fine.
Overall very pleased with Mini of Towson's service and professionalism. Ask for Rose.
Best,
T
alex87f
Mar 25, 2017 03:46 PM
Toolman
Jan 20, 2016 06:50 AM
ltjpunk7
Sep 6, 2015 07:32 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
