R50/53 Harbor Freight el-cheapo torque wrench
Old Mar 4, 2008 | 10:51 AM
  #26
Ancient Mariner's Avatar
Ancient Mariner
Originally Posted by k_h_d
Because of glare against the wrench it would never show up. Here is a quick paint drawing of a part of the scale. Not sure if it helps
Setting is easy. The turnable ring should be marked from 0 to 12 (possibly as 2 - 4 - 6, etc). Turn the ring until it hits the horizontal line -0 should align with the vertical line- then turn left to right to the single digit that is your goal, i.e., 90 on the cross line then 8 on the ring (8 aligns with the vertical line) gives you 98 ft/lbs.
And as Cor Blmy so wisely states: ALWAYS return it all the way down to zero/zero. It will stay in calibration much, much longer. I check my calibration yearly with hanging (known) weights and a bench vise.
Old Mar 5, 2008 | 02:17 PM
  #27
kenchan's Avatar
kenchan
i use those tirerack torque wrenches (1/2" drive) that goes
for like $25. works fine for me.
im in the market for a 3/8 drive one to do mostly suspension
work. the 1/2" one is a tad bit too clumsy... want something
with a 15" or less handle. any recommendations? Perferably
less than $100 since i dont use it that often. (15-100lbs/ft
would do)
Old Mar 5, 2008 | 03:53 PM
  #28
Capt_bj's Avatar
Capt_bj
Survey Says:
There's a lot of discussion of this topic on other sites....Miata.net is one I watch as they have a specific TOOLS forum.
My 2 cents after YEARS of watching:
  • If you didn't use a torq wrnch b4 when putting on your wheels, this might be a significant improvement.
  • The HF cheapo seems to consistently check out +/- 10% of very expensive ones. If you drop it...it may be toast however...that's the nature of the beast
  • I probably wouldn't use one for engine assembly of an expensive engine....certainly not on a Ferrari (sp?) ... and an aircraft mechanic not to mention an Air Force or Navy mechanic?!?@#?@? Yea, right.... these folks worry about the source of their rags. (I ran a "nautical aiport" for 4 years.....their duct tape is good, ship duct tape is bad... )
I use one on my wheels, spark plugs and similar....makes me feel good.....don't mess it up 4 me
Old Mar 5, 2008 | 09:37 PM
  #29
hoonpv's Avatar
hoonpv
Snap-on tools are the best.
Old Mar 5, 2008 | 10:03 PM
  #30
Ancient Mariner
Snap-On tools may be a little overkill for the average driveway mechanic. A reasonably good 3/8" drive torque wrench can be had for under $50 and give years of service if treated with reasonable care (it ain't a hammer, dude).
Old Mar 5, 2008 | 10:16 PM
  #31
COR BLMY's Avatar
COR BLMY
Very well put
Old Mar 5, 2008 | 11:36 PM
  #32
Ancient Mariner
Well all these years of making stupid mistakes outta be worth something finally!
Old Mar 6, 2008 | 04:59 AM
  #33
Speedwing's Avatar
Speedwing
I am still using the same Craftsman 1/2" torque wrench that I bought 40 years ago. It has a similar torque setting graphic to the 1/4 drive you described. I store mine at 15 ft/lbs per the owners manual....not zero!!
Mine is a ratcheting model that "clicks" when it gets to the dialed torque setting.
Woohoo ..... I am in 4th gear now!!!!!
Old Mar 6, 2008 | 07:26 AM
  #34
jibeho's Avatar
jibeho
LMAO
That is exactly how I tighten my lug nuts on my 3 cars in my 25 years of driving I have never had a wheel come of from lose nuts
I have the HF 3/8 for plugs and such only goes to 80 ftp
Old school: 3 grunts and a kick with whatever wrench you could find.
New school: 89 ft/lbs +/- 7 ft/lbs. (120 Newton meters for our brethren across the pond using that new-fangled French metric measurement system)
Old Mar 6, 2008 | 01:52 PM
  #35
Ancient Mariner
jibeho: yeah, I'm pretty much old school, too, what with being old and all, but with the new much thinner rotors that are being used now, I'm more concerned with warping a rotor than having a wheel fall off. One set of pads to one set of rotors (Mini recommended) doesn't leave much room for error.
-skip-
MGBill1186
Oct 2, 2015 06:54 AM
pkillur
Sep 30, 2015 10:51 AM
EVMini
Sep 28, 2015 10:20 AM
Nicefeet
Sep 27, 2015 11:14 AM
Sep 25, 2015 12:32 PM
