R50/53 Boot cover, how is it supposed to sit?
Well I'm new to Mini's and every time I close the boot the cover kinda bounces up, as if it's getting pinched.
What point is it supposed to sit on versus being squeezed by? I see the two pieces of rubber on the hatch but I'm not if the cover sits on top of these?
There isn't any adjustment to the boot shelf. Check underneath towards the rear - there is a tab on each side that fits into a u-shaped notch on each side of the boot. The shelf pivots up and down from there when the hatch is opened and closed.
Try this
I had the same problem, the "bump" from the rear wiper motor would hit the shelf each time I closed the boot door. I took two small pieces of the "smooth" velcro and stuck them under where the rubber pieces on the shelf meet the plastic. This raised the shelf up just enough that it clears when the boot door closes.
Gene
www.bugguardsforbeemers.com
Gene
That's what I was looking for, thanks!
Gene
Gene
09R56
Nov 16, 2022 10:49 AM
Knuckle14
Aug 26, 2015 08:10 PM
