R50/53 I am livid
Old Dec 10, 2007 | 06:44 PM
  #26
Eric_Rowland's Avatar
Eric_Rowland
OK, Crashton, that's just wrong.
But I anyway.
I stopped to take an ice covered MINI shot in Oklahoma (or was it Texas?) and I had to climb out the passenger door because mine was stuck. Then the local LEO stopped to make sure I was ok (and not drunk as I stumbled out of my passenger door!)
  #27
Crashton's Avatar
Crashton
Here's what cha need Mark.......
Drives the babes at the old farts home crazy.
Old Dec 10, 2007 | 06:58 PM
  #28
gokartride's Avatar
gokartride
Originally Posted by agranger
I think that there was some problems with the door handle seals on early MINIs ('04 and earlier, I think) that the dealership knows about. I think that they will replace a rubber bit in the handle for free.
Yes...I agree. 1) what year is your MINI? 2) are you the original owner? 3) have the pieces of the door release mechanism been updated, because freezing of same is a known problem with a known fix?
Old Dec 10, 2007 | 07:01 PM
  #29
mauberley's Avatar
mauberley
Originally Posted by CR&PW&JB
Reminds me of the time I was stationed in northern Japan. We had a 14-inch snowfall and I spent about an hour and a half shoveling out my parking space in front of my base housing complex. I go run an errand and when I get back, one of my not-so-friendly neighbors parked there.
You didn't reserve your parking spot?
Old Dec 10, 2007 | 07:05 PM
  #30
ToBFree's Avatar
ToBFree
Naw, I've been with this for years and still gets an occassional "whassat you're wearing there?" Unfortunately, expensive.
Old Dec 10, 2007 | 09:24 PM
  #31
COOPERIC's Avatar
COOPERIC
Mini's don't need anything to attract babes!
Old Dec 10, 2007 | 10:37 PM
  #32
MLPearson79's Avatar
MLPearson79
Mmmm my favorite! How YOU doin?
Old Dec 11, 2007 | 02:56 AM
  #33
CR&PW&JB's Avatar
CR&PW&JB
Originally Posted by mauberley
That reeks of PWT, but still...
Old Dec 11, 2007 | 05:26 PM
  #34
ToBFree's Avatar
ToBFree
See, it's workin' and I haven't even washed the MINI for 2 weeks. /cackle
Old Dec 11, 2007 | 05:43 PM
  #35
mauberley's Avatar
mauberley
Nope, just SOP in Chicago.
Old Dec 11, 2007 | 05:48 PM
  #36
CR&PW&JB's Avatar
CR&PW&JB
So being PWT is SOP in TWC ?
Reminds me of a note I gave an employee not long ago...
Get this to me ASAP but NLT COB Tuesday.
Old Dec 12, 2007 | 12:09 AM
  #37
navycav3's Avatar
navycav3
hey what happened here!
thread jackers
Old Dec 12, 2007 | 12:15 AM
  #38
Eric_Rowland
Sorry, navycav, we're just trying to distract you so you don't drive your poor MINI off an icy cliff.
Besides, we gave you solutions before the hijack.
Old Dec 12, 2007 | 07:08 AM
  #39
mauberley's Avatar
mauberley
I suppose so.
"Sir, since the VP is such a VIP, shouldn't we keep the PC on the QT? If it leaks to the VC, he might be MIA and we'd all be put on KP."
OK, maybe it's time to stop threadjacking lest the OP become really livid!
Old Dec 12, 2007 | 07:09 AM
  #40
CR&PW&JB's Avatar
CR&PW&JB
Old Dec 12, 2007 | 12:07 PM
  #41
Jenn B's Avatar
Jenn B
Nope, later models as well. My 06 had this problem fixed... twice. I got pretty sick of it. The glass freezing to the sill and not dropping down isn't the issue. Glass can freeze on any car. You can still open the doors if the window doesn't drop. I've done it, carefully, many times.
There are two possibilities:
The door is actually frozen shut. This can also happen on any car.
Or.... the problem I and many others have experienced. The handles do not work. The mechanism gets to cold and doesn't function properly. You squeeze the outside handle and it just stays in or you pull from the inside and absolutely nothing happens. You will have to have the dealership fix this and I really hope it doesn't reoccur. I live in GA... it doesn't even get cold here, but there were a few times that I could not get in my car and I got pretty fed up with it.
Old Dec 12, 2007 | 02:58 PM
  #42
mcs22004's Avatar
mcs22004
The extent to which this is a problem varies by car. My glass used to heavily drag the underside of the gutter--no matter how carefully I tried to open it--and then spring loose, making a sound similar to Daffy Duck's bill as it bent upward when he stepped on a rake. This is not what you want glass to be doing when it's 10 below. Best to carry an old credit card and run it between the molding and the glass from back to front until the window drops.
Funny that they had not improved the design by the 2006 MY.
Old Dec 12, 2007 | 03:23 PM
  #43
MotorMouth's Avatar
MotorMouth
https://www.northamericanmotoring.co...ad.php?t=58006
Old Dec 12, 2007 | 04:11 PM
  #44
Jenn B's Avatar
Jenn B
Hence the "carefully" part. I always gave it a little hand. But it wasn't as bad as the stuck handles problem because, even if it took work, the door would open. With the stuck handle.. it was stuck and that was that. It was either hope the other door would open or crawl out the boot... which I did once.
Old Dec 12, 2007 | 05:13 PM
  #45
ScottinBend's Avatar
ScottinBend
Just use a bit of rubber protectant on the weatherstripping and no more problems.
The frozen handles were taken care of with a TSB. They will replace the pre 05 handles with the later model that shouldn't freeze up.
Old Dec 12, 2007 | 06:19 PM
  #46
MiniStupidfun's Avatar
MiniStupidfun
mine feel like they "stick" sometimes. Not sure what that's about.
Old Sep 3, 2014 | 04:57 PM
  #47
Marie815's Avatar
Marie815
My drivers door is stuck. Won't open from inside or outside handle. Its been high 80's to low 90's so not frozen. Can't get inside door panel off with door shut. HELP!!!!
Old Sep 12, 2014 | 10:04 AM
  #48
RogueMini's Avatar
RogueMini
You have a problem with the latch mechanism/cable. Gotta get the inner door panel off, but as you said, ya can't with the door closed. sry, i dont have a solution for that. Someone else have a bright idea??
Old Sep 12, 2014 | 10:55 AM
  #49
gr8stat's Avatar
gr8stat
I think the people that would best know how to deal with this are a couple of guys over in Hazzard county that go by the names Bo and Luke. I think the last name is something with a D. Seriously, though, I think you need a good repair shop for this one.
Old Sep 12, 2014 | 06:31 PM
  #50
wpoff85's Avatar
wpoff85
I have had this happen several times where my glass froze in the channels. If you lower your door glass the same amount it drops when you pull the handle it still seals and you don't have to worry about it keeping you from opening the door. I do it every year at winter time and just leave them like that all winter. Haven't had a problem since.
