R50/53 Sepantein belt change?
Old Sep 3, 2007 | 09:43 AM
tools's Avatar
tools
Has anyone changed theirs yet and if so how was it done?
Old Sep 3, 2007 | 09:53 AM
xsmini's Avatar
xsmini
First get a belt tensioner tool, then remove the right front tire, and front half of the fender liner (so you can bend it back some and see and get to the belt). Open hood, use tensioner tool to loosen tension on the belt, and remove belt.
Once you have the tool and start looking at it its pretty straight forward. Should only take 15 to 20 minutes.
I tried to do it once without the tool, but was unsuccesful , but others have done it without using one. I'll try to take pictures next time I change mine (next couple of weeks)
Nik
Old Sep 3, 2007 | 10:26 AM
tools's Avatar
tools
thanks
Old Sep 4, 2007 | 06:52 AM
03BRG's Avatar
03BRG
When you release the tensioner a strip of metal in the center of the spring moves out and you can pin it back with a 4mm bolt through a hole in that strip.
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 17, 2015 07:15 AM
FLYM1N1
Aug 16, 2015 01:17 PM
