R50/53 Help! They want me to race with a MCS 07
I think that as mentioned above, it all has to do with the start. These cars are not in two different classes performance wise. It honestly comes down to who is a better driver. If the better driver was in the stock R53 it would beat an R56.
um Quietly go out and see Hubie or the guys from helix and twin charge it to get up to 400 hp or more. You will do just fine
I've been thinking about this...
Well,
according to the unbiased-biased reporting at Car&Driver,
the 07 has a 0-60 of 7.3 and 1/4 mi 15.5s
the 06 has a 0-60 of 7.4 and 1/4 mi 15.6s,
which means the cars perform basically the same (assuming that you both have manual trans.) due to differences of conditions during testing...
The larger wheels have more weight (bad) but slightly larger contact patches (good)... if you want to win, get the pully.
Otherwise, it'll come down to driver skill on launching.
Matt
While what you all say about bench racing is somewhat true...
there's still something fishy. The cars weight pretty much the same. The gearing is pretty close, and the torque levels are very different. If the descriptions are accurate, then the time deltas should be larger. If they're not, then the descriptions have to be off.
Sure there are all those pithy comments about "the BS stops when the green flag drops" or the equivalent, it's also true that simulation can do a lot more than it's given credit for here.
Fact is, that the specifications given and the performance measured are inconsistant. I don't know why, but they are.
Matt
Matt
eatsleepautox
Oct 30, 2015 06:46 AM
Drumsound
Aug 25, 2015 02:25 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
