R50/53 Need your HELP... removing headlights from 2005 Cooper S
Old Jul 20, 2007 | 06:59 AM
redmini04's Avatar
redmini04
Howdy folks,
Does anyone know how, or have directions on how to remove the headlights from the 2004 cooper S? My lens covers have some kind of scum on the inside and I want to remove them so I can clean them. I looked under the bonnet but didn't see any clear way to remove these without having to mess with every screw and nut.
Plus I may have to get the bonnet repainted and don't want mask lines around the headlights.
Many thanks,
Jim
redmini04
Old Jul 23, 2007 | 02:28 PM
beken's Avatar
beken
The headlight units themselves are held to the bonnet by 4 screws...well 4 nuts under the bonnet. I know because mine came loose and I had to tighten them. Once you get them off, I have no idea how to clean the lenses from the inside.
Sorry, not much help here.
Old Jul 24, 2007 | 05:04 AM
slickfast's Avatar
slickfast
i may be wrong, but don't are those things sealed pretty damn tightly to keep all moisture out?
Old Jul 24, 2007 | 06:08 AM
MUShadd's Avatar
MUShadd
yeah, you'll have to pop them in the oven to loosen up the silicon so that you can pry off the lens. and then reapply more silicone once your finished cleaning. you should go ahead and paint the housing while your at it
Old Dec 27, 2007 | 06:28 AM
redmini04's Avatar
redmini04
Thanks all. I don't know what the seal is but inside the lens's there is a slight fog. They used to be crystal clear. I've done nothing to break any seal either. Oh well, not a big deal - just tear them out and clean them.
Thanks again
Jim
Old Dec 27, 2007 | 08:47 PM
donjulio's Avatar
donjulio
If there is a slight fog inside the lens, open the rubber things on the back that access the bulbs when you are not driving
and in a few days it should dry given that its not very humid.
donjulio's Avatar
donjulio
Or
Take out the high beam bulb, and attach a microfiber cloth to the end of a long chopstick.
Toolman
Jan 20, 2016 06:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
