Official NorCal Check-In!!
Old May 10, 2011 | 11:25 AM
  #101
Vinyl Styles's Avatar
Vinyl Styles
CocoMini
Very Nice!!!
I'm up for an SF meet! I'm sure the rest of the NorCal group would be too.
Old May 11, 2011 | 11:22 PM
  #102
clockwerke's Avatar
clockwerke
Congrats CoCoMandy!
I'm n, lets pick a date....
Old May 13, 2011 | 09:36 PM
  #103
craigplex33's Avatar
craigplex33
What's up everybody? Just checking in...
Craig
'04 MCS
Indi Blue/Black
Walnut Creek
Old May 16, 2011 | 08:06 PM
  #104
Joey Mojo's Avatar
Joey Mojo
Did anyone else here take part in the Helix FMIC group buy? If so, how does everyone feel about an install party? I'm dying to meet some local MINI-heads and get my hands dirty!
Old Nov 7, 2011 | 09:18 PM
  #105
arsci's Avatar
arsci
I know this is a few months old, but thought I'd throw my info out there!
Ryan
2008 MCS
Silver
I go to school in Rohnert Park (Sonoma State), live in Petaluma during the school year, and am at home in Pleasant Hill during summer and whatnot.
Old Nov 8, 2011 | 09:56 AM
  #106
Vinyl Styles
We are planning on setting up monthly meets here at the shop. Last friday of every month.
Keep posted on the site - www.vinylstyles.com
Old Nov 8, 2011 | 10:50 AM
  #107
Grimnebulin's Avatar
Grimnebulin
It's alive, IT"S ALIVE!!!!
Old Nov 21, 2011 | 08:16 AM
  #108
SMOG's Avatar
SMOG
Alliance Member
Driving Lamps & the CHP
Hi you to all Calif MINI owners.
I did not know where to Post this so I put it here.
What are California's regs regarding uncovered driving lamps and fog lamps? I am planning a trip through the Bay area and then on south to San Diego, from Seattle. Love to know your thoughts!
Thanks in advance.
Old Nov 21, 2011 | 01:01 PM
  #109
kazlot's Avatar
kazlot
V C Section 24402 Auxiliary Driving and Passing Lamps
24402. (a) Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height of not less than 16 inches nor more than 42 inches. Driving lamps are lamps designed for supplementing the upper beam from headlamps and may not be lighted with the lower beam.
(b) Any motor vehicle may be equipped with not to exceed two auxiliary passing lamps mounted on the front at a height of not less than 24 inches nor more than 42 inches. Passing lamps are lamps designed for supplementing the lower beam from headlamps and may also be lighted with the upper beam.
V C Section 24405 Maximum Number of Lamps
24405. (a) Not more than four lamps of the following types showing to the front of a vehicle may be lighted at any one time:
(1) Headlamps.
(2) Auxiliary driving or passing lamps.
(3) Fog lamps.
(4) Warning lamps.
(5) Spot lamps.
(6) Gaseous discharge lamps specified in Section 25258.
(b) For the purpose of this section each pair of a dual headlamp system shall be considered as one lamp.
(c) Subdivision (a) does not apply to any authorized emergency vehicle.
V C Section 24411 Auxiliary Lamps Off Highway Use
Auxiliary Lamps: Off-Highway Use
24411. Notwithstanding any other provision of law, a vehicle may be equipped with not more than eight lamps for use as headlamps while the vehicle is operated or driven off the highway. The lamps shall be mounted at a height of not less than 16 inches from the ground, or more than 12 inches above the top of the passenger compartment, at any place between the front of the vehicle and a line lying on a point 40 inches to the rear of the seat occupied by the driver, shall be wired independently of all other lighting circuits, and, whenever the vehicle is operated or driven upon a highway, shall be covered or hooded with an opaque hood or cover, and turned off.
Old Nov 21, 2011 | 01:13 PM
  #110
SMOG's Avatar
SMOG
Alliance Member
(1) Headlamps.
(3) Fog lamps.
(4) Warning lamps.
(5) Spot lamps.
Thanks for all the info!
It appears that the MINI's factory fogs are way below the 24 inch required minimum and the factory driving lamps are also to low since the bottom edge of the lamps are 23 inches. An officer with a tape measure and a headache could cause grief!!
So the foggiest part of my trip (southern I-5 and the big Sur Coast) I will not be able to use Fogs. Whoopee for California for creating an unsafe condition with the stroke of a pencil!
Old Nov 21, 2011 | 01:51 PM
  #111
kazlot's Avatar
kazlot
I believe the OEM front fogs have an exemption, for CA, on height much like the pre-05 rear fog lights did.
I didn't realize the factory installed driving lights. You would think they would have an exemption as well and be legal.
My guess is if you have just two extra lights you'll most likely be okay. Just bring a pair of caps in case.
Having said that this is California so all bets are off.
Enjoy the ride!
Old Nov 21, 2011 | 01:58 PM
  #112
SMOG's Avatar
SMOG
Alliance Member
LOL! Yes, the late great state of mind called California!
I was escorted to a local PD so the officer could get a tape measure and his code book to go over my '59 Bugeye Sprite in 1964, and I doubt that that sort of mentality has changed
Thanks again for the input. I will throw in a couple of pairs of Hella Caps, and maybe a case of doughnuts
S.
Enjoy the ride!
Old Jan 5, 2012 | 11:23 PM
  #113
Underscore002's Avatar
Underscore002
Joe
Cooper S
Cream
2006
Rohnert Park
Old Jan 6, 2012 | 12:28 AM
  #114
silhouette88's Avatar
silhouette88
Hey Lyle, are you still doing these? I'd be up for swinging by at the end of the month and meet some other NorCal peeps. I could probably only hang during the day though, I have work obligations at night.
Old Jan 10, 2012 | 04:05 PM
  #115
Yoda Mini's Avatar
Yoda Mini
I'm the new guy here. Just picked up my first Mini last night.
Roger
05 MCS (Yoda)
British Racing Green
Home - Tracy
Work - Hayward
Old Jan 10, 2012 | 04:11 PM
  #116
Flamewinger's Avatar
Flamewinger
I'm interested. It this a day thing or an evening Dinner?
astroblack
Feb 8, 2017 06:16 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Mrniksmif
Sep 28, 2015 12:07 PM
///Matthew
Sep 15, 2015 03:45 AM
mxr662
Aug 31, 2015 02:50 PM
