New York/New England New York, Connecticut, Massachusetts, Rhode Island, Vermont, New Hampshire, and Maine
mechanic needed for a classic mini???? HELP
Old Nov 7, 2005 | 03:44 PM
NYMINIME's Avatar
NYMINIME
I just purchased a classic 2000 mini with sport package (1.3 Liter Fuel Injected motor), left hand drive.
The motor seems to be loose when i am engaging out of 1st or reverse when there is more torque to the motor. It sounded like a thump or clunk against the firewall. I am wondering if one of the motor mounts are loose or damaged.
Does anyone on this board know of a good mechanic or a shop that specializes or works on these classic minis as I would like a complete check/tune up on this car before handing it to my wife. I am located on Long Island, NY.
Thank you ALL!
Sam
Old Nov 7, 2005 | 05:08 PM
Rick-Anderson's Avatar
Rick-Anderson
Sounds like typical torque rattle and roll associated with classic Minis but you want o be sure. Too much movement can damage your exhaust mounts. Contact these guys - I don't think they work on Minis but they will be able to steer you in the right direction: http://www.minicityltd.com/pgOrder/order.html
Old Nov 7, 2005 | 06:01 PM
NYMINIME's Avatar
NYMINIME
noise from engine compartment
yeah that does makes sense as when the car is rolling and moving at higher speeds, there are no signs of such noise. It only happens when I am getting off 1st and reverse when there are more torque movement on the motor. Anyhow, I will have a mechanic thoroughly check it on the lift to be sure.
Sam
Old Nov 8, 2005 | 08:59 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I never owned a classic with injection, but on older Minis, the engine mounts were rubber vulcanized to a backing plate. Over time, the vulcanizing can deteriorate and the mount separates. They aren't a HUGE job to replace. I think the ones I did, I didn't even have to remove the motor.
phrza81
Oct 10, 2015 11:37 PM
MiniJess
Aug 10, 2015 09:51 PM
marendt428
Aug 8, 2015 04:44 AM
