Navigation & Audio Has anyone swapped speedometers yet?
Old Mar 22, 2013 | 05:49 AM
kerrys914's Avatar
kerrys914
I have a CM with the LARGE speedometer and am curious if the speedometer which is used for the connect/nav system could be retrofitted without having mini connect.
Old Mar 22, 2013 | 06:55 AM
mbabischkin's Avatar
mbabischkin
Without MINI Connected you'll end up with a big blank spot on your dash because the video display won't work...
Old Mar 22, 2013 | 07:24 AM
kerrys914's Avatar
kerrys914
I have plans for that big blank spot
Old Mar 22, 2013 | 09:26 AM
mbabischkin
The other issue is that without Connected you completely loose the radio. The radio is controlled using the connected joystick and the display. The display is not a touchscreen...
Old Mar 22, 2013 | 09:37 AM
kerrys914's Avatar
kerrys914
True.. I just noticed that too. I was hoping the radio would fit (with mods) in the lower section of the connect speedo but it looks like it will be too wide..
Oh well...
elverado
Jan 18, 2022 02:51 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
B1mm3r101
Oct 1, 2015 06:22 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
