Navigation & Audio 2003 US spec MCS wiring Harness
Old May 3, 2006 | 02:53 PM
labeda14's Avatar
labeda14
Greetings,
i was about to replace the stock boost radio and noticed that there apears to be a blue rubber material in the factory radio harness right where the pins from the aftermarket harness should plug in. has anyone else noticed this? Will the pins push through the blue stuff or does it get removed? I am pretty sure i have the correct harness, i can try to take a photo of the blue stuff, but i wanted to see if anyone else has dealt with this. i am completely bypassing the factory radio system (all new speaker wires, remote turn on lead, amplifiers, subs, rca's and such) so i don't really need the harness, i could tap the power and accessory wire and just ground it to the frame, but if the harness works, i'd just as soon use that. any help would be much appreciated.
thanks!
Doug
Old May 4, 2006 | 03:27 PM
Z-Mini's Avatar
Z-Mini
Originally Posted by labeda14
Greetings,
thanks!
Doug
Which aftermarket harness do you have?
I just (today in fact) installed an after market cd/radio headunit in my 06 MCS. The Metra Harness I bought mated up fine but did not have wires for switched power or illumination. I bought a second harness and stole pins from one to fill the other. Working fine.
-Randy
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
Chasp
Sep 4, 2015 09:31 AM
PSIChocolate
Aug 13, 2015 12:46 PM
DWooderson
Aug 10, 2015 09:12 AM
