Navigation & Audio Does XM direct connect antenna placement cause leaks?
Old Jun 25, 2005 | 08:50 AM
Fidge's Avatar
Fidge
I just did the XM direct connect. Its great cost $170.00 for the blitzsafe adapter and xm universal tuner at Audio Warehouse. One question though, I ran the wire for the antenna through the rubber thingy at the top of the hatch and down the c-pillar into compartment where connection is made. Is the seal on the rubber piece where the antenna comes through affected. Will the wire sticking out cause water leaks???
Old Jun 25, 2005 | 07:10 PM
not-so-rednwhitecooper
run it out the bottom of the tube, water cant sit on the bottom of the rubber, it will just drip off!
Old Jun 26, 2005 | 08:19 AM
Fidge's Avatar
Fidge
Thanks, I originally had it out the top. Just changed it to the bottom, glad I asked :smile:
Old Jun 27, 2005 | 02:41 PM
DaveTinNY's Avatar
DaveTinNY
I have my antenna directly behind the factory am/fm job and i've had no leaks. the xm antennna wire is so small that i think the rubber seal just compresses around it easily. looks good and it funKtions well. :-) no leaks as yet.
Old Jun 30, 2005 | 03:39 PM
MyMini05's Avatar
MyMini05
Here is where I mounted the XM antenna. The wire tucks under the rubber at the covertible room seal. There has been no problems yet with rain getting in.
Hope this helps. - Fred
speedyg56
May 18, 2020 08:52 AM
Aug 24, 2015 02:09 PM
bugeye1031
Aug 15, 2015 08:14 AM
