Navigation & Audio OEM head unit with factory SIRIUS
Old May 22, 2005 | 09:15 PM
allyrand
has anyone installed an aftermarket head unit using the factory installed Sirius antenna..the reason I ask is the antenna the dealer installed on mine is a 2 wire antenna...and all the new aftermarket Sirius Receivers..seem to be the new 1 wire antennas...I would like to keep the factory antenna with the fitting for the regular am/fm antenna that screws into it....I have done a search on this with no luck...any help would be greatly appreciated...thanks
Old May 24, 2005 | 06:20 PM
ninjamini's Avatar
ninjamini
There is no adapter that goes from a two wire (old antenna) to a one wire. You have 2 choices:
1. Buy a new antenna. Choose only the terk sir mini or the brand new dot. the dot may not even be in stores yet. I just got mine yesterday. It fits right behind the fm antenna. run the wire into the gromit that houses the rear window washer wires.
2. Use the factory antenna. remove the plastic housing - it has 2 clips. one wire is for satelite and one is for terrestial. If you live in a rural area it wont matter if you live in a city it will.
Doing this you in effect dont have axcess to the ground repeaters. but if you dont live in a city you will never use them anyway.
blackie
Oct 2, 2015 07:41 PM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
yashmack
Aug 15, 2015 03:11 PM
veevsato
Aug 5, 2015 04:42 AM
