Navigation & Audio Harman Kardon speaker wiring
Old Sep 30, 2018 | 08:23 AM
cavaliers60's Avatar
cavaliers60
I am in the process of replacing the whole audio system in my Mini. I have the Harman system, and I’m familiarizing myself with the wire layout. I haven’t been able to figure out the wire SIZE though. I would assume they would be a heavier gauge wire to handle the extra power from the amp to the speakers compared to factory?
My my plan is to use the existing wiring. I will be replacing the speakers with some Infinity Kappa series speakers running off of the Infinity Kappa 4 channel amp sending up to 100 watts of power to each channel. These are component speakers, so I can separate the wires from the Harmon amp and hook them up to the crossovers that come with the speakers (that’s the goal anyways). But I want to make sure I get the full benefit of the new stuff.
The end end result will basically be the same setup. The tears will mostly be used for the low end so probably won’t hook up the tweeters there.
Everything will be ran from the Apline HU I installed using two RCA sends so I won’t be using the two factory sends.
So main question is if anyone knows the gauge of the Harman Kardon wiring.
wetotter
11
May 28, 2016 07:57 PM
ladzio
Navigation/Audio
Jun 11, 2015 10:55 AM
hulagirl43
Jun 26, 2014 10:26 AM
flewdcoop
25
Sep 2, 2009 10:41 AM
